Velossa Tech Design Big Mouth for 2019+ Ranger
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
Just a FYI.....I've had mine installed since last fall (right when they started shipping them) if my MPG's went up it's not noticeable or minimal at best for me.....and I have a light right foot and tuned by Unleashed.
I saw an improvement once installing mine. I did open the hole up in the valance cover. I’d estimate a 1 to 2 mpg improvement over stock. Definitely an improvement on highway acceleration get up and go now.
Tim H.
TJ
Maryland
REALTOR
Same, after my install highway mileage went from 26 avg to 28mpg.
Racket
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I never noticed (perceptible) 'performance ' gains or noise, just improved highway mileage. Summer gas is here! More expensive but better mileage.
Speaking of; we've all been on 'summer gas' for a month. Anyone seeing improvement in MPG's?
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
Since putting the Big Mouth on over the winter, my mileage has gone up (per the gauge) from 17.4 to 18.7 lifetime, that is, since summer 2019. Admittedly, this is totally unscientific since we have changed over to summer, summer gas, I am doing more freeway and highway driving post-pandemic, and, since I am more aware of mileage issues thanks to the the BM, I may even be hitting the turbo less heavily than before. Still, with a tuned engine, more aggressive tires, FX4 (heavier, less aerodynamic, no air dam, etc.), and a two-inch leveling lift, 18.7 (and climbing) is not bad in my book! My 2014 Explorer Limited never hit 18 MPG in its whole life, and so I am satisfied with my Ranger MPG, and, yeah, the BM may be helping....
Edit: Make that 18.8 lifetime!
Re-Edit: Make that 18.9!
Neo-Re-Edit: Nineteen big ones, baby!
New-Neo-Re-Edit: 19.9!!!!!!!!!!!!!!!!!!!!!!!!!!
Racket
Racket
Here and There
Transient
...giving this thread a bump for newer owners. My highway mileage gains persist although they took a slight (looks like just over 1/2 MPG) hit since I 'nearly' levelled the truck by raising the front an inch and a half.
It makes me wonder if the extreme rake of the factory setup was intentional to hit those MPG claims.
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
So, another update from owners? How you like it with this much usage? Performance gains? Mpg gains? Sound gains? Cooler temps?
Langwilliams
Langley
Lorain, Ohio
I put one on figuring it it didn't do much it was pretty cheap. I have this on, the smooth down tube from the air box an the high flow filter now I just need the larger intake for the air box.
dondonbabyraptor
Brandon
San Diego
So do you notice any gains even though previously you thought it wouldn't do much? MPG gains, sound gains, cooler temps?
dondonbabyraptor
Brandon
San Diego
Well since not many long term Velossa users are saying much, I went ahead and bought one. Will report back if anything changes even in the slightest bit, even if placebo or not. Guess we will see.
Langwilliams
Langley
Lorain, Ohio
I track my mileage every tank an I did think I saw a slight increase but it went away when I leveled the front 1.8"
I run a high octane tune an jump on it some an still knock down 21-22 every tank.
dondonbabyraptor
Brandon
San Diego
Thank you for the insight Langley. Excited to install mine and see what it's all about.
RBTremor
Rod
Detroit, MI
1966 Mustang Convertible, 2019 Mustang Conv. 2.3L
Looks like an invitation to suck in water when fording? It lowers the factory snorkel and opens it up. The factory intake sits on top of the shroud and seems to be designed to be in a spot that water would not easily find the opening. this scares me of water being easily "forced" into if hitting a deep water event. Thoughts?
dondonbabyraptor
Brandon
San Diego
IIRC, your alternator will go before the intake since it sits much lower. Also, please correct me people if I am wrong but there isn’t enough air sucking in from this because it’s not directly attached to the intake. It’s “goal” is to provide colder air near the air scoop. Not one full connection.
