Tremors and high octane fuel
Zvedza
'21 Ranger Tremor, '04 SVT Lightning, '16 ZX-10R
93 at shell/chevron/costco i always saw good mpg. I switched to 87 when prices got out of hand saw a .5-1mpg drop and it ran worse.
That said, with the FP tune, 33s, fox 2.5s i had roughly 18.0-18.6.
My raptor i get 18 mpg lol
Slightly offtopic, I will say a bed cover made huge difference on this truck, i tried exhaust, intake, that velossa tech thingy, none made a dent but that bed cover did a good bit, of course it went close to stock when it leveled.
Bed cover on the f150 didnt do much oddly enough.
EDIT: will say it always gave me slightly better mpg with a bottle of techron or lucas mixed in.
In reality, you'll only get better fuel economy with premium if it has a lower ethanol content. There have been way too many studies on this to even begin to doubt it. But the internet is going to be the internet. :)
And from what little I know, isn't ethanol detrimental to engines?
I use this stuff, mainly as a carry over from when the "Scorpion-Who-Must-Not-Be-Named " applied tremendous damper & graphene pressure on us all - from the 303 Gold Eagle company and supposedly for ethanol-blended gas:
https://www.goldeagle.com/product/sta-bil-360-protection/
Jhbryaniv
2023 Ranger Tremor
that little skinny pedal, tires, accessories, temperature, altitude, quality of fuel . . . Everyone will have a different result.
For me, it is the skinny pedal, bed rack, added weight and I love feeling that boost that makes me have low mpg. it is a fact of life.
Zvedza
i know, i thought the supercharger i slapped on would lower the front and get more mpgs, but for some odd reason im getting less, may lemon law it
Friday yet?
‘23 Lariat Tremor, Focus ST
Jhbryaniv
2023 Ranger Tremor
I bet it is because of the poor engineering that caused the rear of the truck to already bo so high that the tailgate is acting as a sail, and you will need to remove the bed to increase MPG's.
bostonburner
Boston
2019 Ranger Lariat Fx4 hot pepper red metallic
That is a good point, since I've owned my truck I've only driven about 10 miles with the tonneau cover open. I'm basically running the same setup as you except I have 265/70 r17 tires which are about 31.6 inches vs 33's.
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
I'm not sure if this makes sense or not; but to me it seems if we were seeing huge variances in efficiency from 87 to 91/93 octane it would not speak very well to the performance of the engine. We shouldn't be seeing 3-4 mpg differences from fuel octane rating alone. There are so many freaking variables in calculating a vehicles per-tank mpg over the course of a year that could account for variances that I don't care to list right now - but let's leave it at daily wind speed and direction alone.
I think it's good that we can choose the fuel we'd like to use for the reasons we'd like and achieve similar performance in MPG.
I choose 91 because where I live the fuel is so expensive anyhow, I'm really only looking at a 40-cent per gallon difference to go premium. And with premium I get the "free" Shell V-power detergents that they put in their 91 and I don't have to fuss with any fuel system additives to de-gunk injectors and whatnot.
Dgc333
21 Ranger Lariat
You don't understand engines very well do you? Under light load/ cruising you will have less advanced ignition timing compared to high load/WOT. When you have more available power(to an extent)you have the potential have better MPG especially at cruising speed since the Engine won't have to work as hard.
As for your 50+ years in driving I'm going to guess a majority of the vehicles you owned simply required 87 and nothing more. Take a vehicle that requires 91 and up and do a comparison between 87 and 91. I guarantee you will see a difference. The Ranger has more tolerance compared to some other vehicles on the market since Ford did state you can run 87.
I am going to say that you do not understand engines and the timing needs of the engine under various operating conditions if you believe an engine doesn't require more timing when cruising than at WOT. Simplest way I can explain it is to think of an older engine with a distributor. There is a mechanical advance that varies the timing based on rpm and a vacuum advance that varies the timing based on manifold vacuum level. When cruising your throttle is barely cracked so the manifold vacuum is high and the vacuum advance can is adding timing on top of the mechanical advance. A typical sbc Chevy wants about 35 degrees of advance for maximum power. A typical mechanical advance will have all the timing in around 2700 to 2800 rpm. Say you are cruising at 2200 rpm you won't have all 35 degrees of mechanical, maybe 30, but you will have high manifold vacuum. A typical vacuum advance will add 20 degrees of timing when you have high manifold vacuum. It is not unheard of for the engine to have 50 degrees of timing when cruising when 35 degrees is ideal for WOT and max power. Modern engines in general require much less timing because of more efficiently design cylinder heads and combustion chambers. A modern LS engine may only need 28 degrees of timing for max power but will still require more timing under light load cruising to see maximum efficiency.
As for my 50+ years of driving the majority of the vehicles I have had required 91/93 octane. I have been driving turbo charged 4cyl cars continuously for the past 38 years. My 13 Focus ST was the first one that said 87 was acceptable. The ST, my two Ecoboost Mustangs and the Range I have experimented with 87 and 93, never saw a difference in mileage and the reason being detonation rarely happens under cruising conditions so higher octane fuel will not have an impact.
As for my expertise I have been working on cars and engines since my teens. In college I had several lab classes where we performed experiments on all kinds of internal combustion engines to determine how to maximize power and economy. In college I taught an ASE engine basics class for mechanics looking to get ASE certification. I was a crew member on a NASCAR Late Model Sportsmen team all through college and for a number of years afterwards. I have built a number of performance engines over the years for my own hot rods and for friends. I have been a student of automotive performance all of my adult life.
Scott_Anderson_
Scott
Arkansas
2023 XLT Tremor - Cactus Gray
I’ve been running 93 since I bought mine in April. When it was stock, I’d run avg 21-22 mpg mixed city/hwy driving. Threw a rough country soft tri-fold tonneau on and, as another member mentioned above, the cover does make a big difference. I was averaging closer to 22-23 mpg. At that point, I was trying to eke out the best fuel economy possible.
But, coming from a Bronco Sport with the 2.3L engine, the main reason was the improved driving experience, shifting, responsiveness, etc. I played around with different octanes and hated how the 2.3L eco boost ran on 87 octane, which is why I ran 93 in the tremor from the start.
After I installed the Ford Performance tune on the Tremor, I’ve seen a substantial decrease in my fuel economy, from 22-23 mpg to now around 19 or 20 mpg, but no regrets.
On a side note, my Explorer Sport has the 3.5L ecoboost, and I’ve always run 87 Octane it and it runs great. No issues at all.
Yeah ASE is outdated unfortunately. With everything today it is all electronic based and the manufacturers have a nice thing called the ignition timing table that simply states what ignition timing should be with RPM and load. When cruising there is usually (key word here) low load compared to to WOT. With WOT you clearly want max power and the ECM will give you more ignition timing with that. I have seen this first hand with a few different vehicles that are computer controlled. Remember l, these are not the "good old days" anymore where all you need is a screw driver and a crescent to get yourself going down the road. There is a lot more involved now.
Saucy
Utah
2022 Ranger Tremor, 2019 Hyundai Kona
Software Slave
I noticed a minor difference in fuel economy (+2 mpg ish) running 91 octane vs 88 (mid grade). What really sold it for me was the throttle response from 0 mph was much better
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
In terms of fuel economy and timing, the big impact will be when cruising under low load. The timing would mostly be advanced due to a low load on the engine, less so due to low engine RPM. The engine control would be maximizing the advance just below the detonation point, so higher octane fuel of good quality that reduces the inclination to detonate would allow some additional advance which would increase fuel mileage . Obviously the most impact would be those who drive long distance at constant speed, so city driving would negate much gain. The impact of timing at WOT would be to retard under heavy load and advance under low or no load.
