Tremors lifted from factory in front only ?
CarbonTremor
21 Ranger Tremor, 04 Jaguar XJR, 21 Bronco Sport
I was under the impression the tremor sits .8" taller from factory in both the front and rear. I was told today the front is actually raised approx. 1.25" & the rear is the same height as non tremor's?
CarbonTremor
CarbonTremor
Tremor rear leafs packs add about .5 inches in rear height over non Tremor single leafs.
Cool. I thought the multi leaf rear spring attributes to a higher ride in the rear. Do the rear shocks have additional travel ?
Not sure about that.
I'd guess so. I know they're Foxs and the lowliest Fox rears available for our trucks allow more.
Also, the .8 inch addition you're thinking of is ground clearance for the Tremor. It doesn't mesh with lift numbers because the the ground clearance is all gained by the larger tire size, which the lift accomodates.
