Transmission fluid overfilled
GTHAYS
Glynn
Nevada
2020 Ford Ranger XL STX
23 Years in Prison on the 8 hour installment plan. (Retired, intact)
If you were good before and nothing has changed, I would enjoy your trip and not be concerned about it.
I found that the fluid level is sensitive to temperature, how it's been driven prior to checking and especially if it's on flat ground when checking.
I also found that if you put it up on a hoist to check the fluid, you need to rack it like it sits on the ground, if you just rack it on the flat of the frame, the front end goes up in the air first and the fluid will be a little low compared to how it sits on the ground.
But really, everything affects the fluid level, just ride the height alone, heavy loads in the bed, towing loads, no loads, lift kits, leveling kits and lowering kits, there are many things, that's why it's a range.
To me, the important thing is, you just want to make sure it's not too low, that's when shifting is affected.
Got mine today. Thanks Sir for the work you did to make it happen. Sad FORD couldn't do it. Again, I would say It's a great deal vs a new tranny (Not Budlight) Thank you sir for doing this.
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
It's going well, it's staying at a steady pace, so I'm able to keep up with it! Thanks for asking?
Mike,
What size is the AN fitting that goes into the trans.
In Canadian that would be around 4 and two quarters or 4 and 4/8 or 5 minus .25 minus .25...
Very close, it’s point two-four.
Those who know, know.
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Mike,
The hose end size?, or the threaded hole in the transmission size?
5thranger
Gary
kansas
The fitting that threads into trans, if I needed to buy another fitting like that what would it be. When I installed the corners on the fitting got roughed up by wrench a little bit.
Fitzmotor
Gold Sponsor
Saugus
It's a custom fitting I had made, the wrenching size has been reduced from 1 1/8" to 15/16", and it's shorter. If you bought a off the shelf fitting it would change the calibration of the dipstick, I may be able to send you one if you want one, I should have some extra ones when I get done with the next batch.
5thranger
Gary
kansas
Yes, that would be great let me know. Thank you
