Transmission fluid change
neat1954
Tulsa,Ok.
2022 XL Supercab FX4
I'm going to lose my rewards points next month so I need to do something. At 38000 miles should I get a tranny fluid change? What would you suggest.
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
Definitely wouldn’t hurt. I changed mine at around 80k miles. Roughly 1/2 the miles that Ford recommended before it needed to be changed. Mine looked like coffee and the new was almost clear. The filter looked surprisingly clean though. I changed it as well since I was already that far into the job plus the mileage.
JimJa
Bondurant, WY
Coincidently I just had a long talk with the owner of a larger transmission repair facility yesterday because I was concerned about maintaining my own 10R80 transmission in my '24 Ranger Raptor.
I specifically asked about repairs for the newer 10-speed transmissions after Ford changed the CDF drum in early '22. He said he hasn't seen any of Ford's newer 10-speeds in for repair after Ford made the change, although acknowledged those newer models typically have fewer miles.
I asked about transmission service. He said 60K was okay as long as you didn't tow or tow in hot weather which can get the fluid hot. I didn't ask about how often when towing, but clearly more often than 60K. Personally, I intend to make my initial transmission fluid and filter change at 25K and every 50K thereafter. Same for the transfer case because there are clutch plates that engage/disengage while in "4A." Not all Rangers/F150s have the 4A transfer case option however.
GM's co-developed w/Ford's 10-speed is having problems to the point there is a class action law suit. The problem he said, and I've noted elsewhere, is the long wait for parts - up to seven months. That's along time to be without your truck, particularly if it's a work truck. Don't know the differences between Ford and GM's 10-speed.
Stevedbvik1
2022 Ranger Tremor XLT
Your Raptor has the 10R60 in it. Shouldn’t have the issues that the 10R80 and 10R 140 had. But those maintenance recommendations are good advice for the 10R60 also.
