Tire Pressure?
peterson1604
Scott
Escanaba, MI
Body shop manager
So my gauge says 30 psi but the truck says 32psi. How accurate is the trucks tire pressure monitor?
peterson1604
peterson1604
Scott
Escanaba, MI
Body shop manager
Thanks, just ordered it. ?
I've had it about a year now and really like it especially when you're airing back up. It's easier to over fill by a couple pounds and just use the bleeder to get it right where you want it instead of attaching the air hose over and over.
Pinepig
Charlie
Sacramento
Last count was 12
lol
HenryMac
Mech. Engineer - Retired
Also remember... the actual tire pressure increases as the tire warms up.
peterson1604
peterson1604
Scott
Escanaba, MI
Body shop manager
I got them all adjusted to 31 PSI after about 15 minutes of driving. Temperature is in the low 40s and winter is on its way here in Michigan so I'll adjust after the gauge arrives from Amazon.
What pressure is everyone else running at? I have the FX4 with the 17-in wheels.
HenryMac
Run the pressure listed on the drivers door jamb of your truck. Mine has Light Truck tires, so the pressure is higher.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
The TPMS on my truck has been dead on (within ~0.5psi) to my actual gauge anytime I check. And I do it often since I air down for offroad.
My door placard says to run 30psi, but I found with the "floatiness" of the front, running 32-34psi was more comfortable and helped to settle the suspension out a bit.
I just upgraded from the 255/65/17s to 265/70/17s and am still working out the pressure for these, but I suspect I'll wind up in the same range.
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
Whenever I fill them up, I put in 35 PSI all around, which give a firm but not rough ride. I understand that, given weather conditions, time of day, nature of the drive, etc. that actual pressure will vary up and down, but not so much that I feel the difference in a negative way.
