Tire pressure
ljames
Larry
Phoenix, Arizona
jameselectronics.com
2020 Ranger 4x4 FX4, 2011 CRV,1998 Ford E250 super
contractor
I have searched this site to see if any one knows how to recalibrate the computer to allow 18 inch Ford Blackout rims @ 32 psi VS the factory 17 inch tire wheel combo @ 38 psi. currently running about 38 psi to get the TPMS to not show error, and it is a bit rough with the FX4 package. Basically want to recalibrate TPMS to 32 psi. Did I miss a thread on this?
ljames
ljames
Larry
Phoenix, Arizona
contractor
Seems to not be a problem any longer.
Perhaps Ford did a update via WIFI- it could be that if all tires are the same psi, the computer says OK?
32 psi is no longer a problem with tpms
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Sometimes you have to drive a bit for them to reset. Speaking generally.
Cabose-1
Eli
Student
Weird...my light oy turns on if i let air out below 28 psi
Non fx4
Xlt 4x2
You could try using Forscan to change the TPMS placard pressure in the BCM to a lower pressure for both the front and rear.
