The wrong oil filter bought on Amazon destroyed my engine
drcollie
Duane
Alexandria VA
2022 Ranger Lariat "Snow" edition
Last Friday my wife was driving our 2020 Ranger XLT when the oil pressure light came on and she pulled over immediately as the truck shut off. Upon arriving to where she was, I saw there was no oil on the dipstick. I had brought along two quarts just in case, and put them in the truck, they promptly flowed right back out again. I pulled the rubber flap off in the driver's side front wheel to look at the oil filter and it had come off the truck and was laying in the inner well. I had changed the oil myself four months earlier and had bought the oil filter off Amazon, a Fram that Amazon set "Fit my vehicle". When installing it in April, It seemed to be slightly smaller that OEM, but that happens a lot so I didn't pay much attention to it. I went down to the Auto Parts store, bought a new OEM Motorcraft oil filter / 6 quarts and figured it would start right up after all was put together again. It did not, the battery was fine but the engine would not turn over. I had the Truck towed to the local Ford dealer.
Three days later they called me up with the bad news, my engine was seized. I went up to look at it put a breaker bar on the nut on the harmonic balancer and it would not budge. A new Long Block with labor was $ 13,500 installed. I said "Why a Long Block? This truck has only 13,200 miles on it, let's price out a short block and move the components over." Their lead mechanic said we could do that, but once he gets into the engine the Turbo will likely be fried from oil starvation, the cam journals ruined, passageways problematic, he didn't recommend it.
I paid $ 31,500 for this truck new two years ago, before pandemic pricing cranked the prices up. It's a company truck, so I was able to Section 179 Deduction on it back then, Both my wife and I really like the Ranger and its been super solid. I'm not big on junkyard engines, so did I want to spend $ 13,500 and have it down for a month to fix it? The dealer had a exactly one new Ranger on the lot, the limited edition "Snow" in the Avalanche color (Lariat) and I had them put a number on the 2020 with the locked up engine towards the MSRP on their new one. I was expecting the dealer to offer $ 8K to $ 10K on the truck, instead they told me $ 17K towards the new 2022, so I took the deal and can Section 179 Deduct the new one in my business as well. No headache on engine replacement and no down time.
I researched that oil filter from Amazon that "Fit my Truck" in the Amazon Garage. Turns out it's a Honda Civic oil filter and fits a few Hyundais and Toyotas as well. Obviously. the thread pitch was different and over those four months vibration loosened it enough to come off the engine. I went back to Amazon and see that it no longer lists that oil filter as fitting a 2020 Ranger, but I cannot prove that it did back in April when I purchased it, either. This was an expensive lesson to ALWAYS double check your oil filter fitment when going cross brand and doing it yourself. If it is not the same exact size, or the threads don't feel right, stop and check. I've done probably 1,000 oil changes in 50 years on all sorts of equipment, never had this happen before but you can be sure I won't trust third party oil filters to fit based on a website any more.
It's not all bad though, I got a new and nicer Ranger. Still the best truck in class even if it does have an oil filter access point that clearly was an afterthought.
Admiration to you for not having gone postal...glad it all worked out well...I only use OEM for this reason...
Fram filters have been utter garbage for a number of years now, even if they do fit the intended purpose. I always use either an OEM filter or a WIX. Both our vehicles use the same filter now (Motorcraft FL-910s) so I ended up buying a dozen from rockauto and they were only like $3.50 a piece!
Sounds like things worked out reasonably well however. It sucks that it happened though.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
So sorry to hear that but glad it worked out for you. The filter on our diesel models is in the same crappy place and you have to remove the rubber flap the same to access it. Then to make matters worse it's a Euro cartridge type so when you unscrew the plastic housing it spills dirty diesel oil all over the chassis rail, and then you have to extract the paper guts, and replace it with the new filter, fit a new o ring,. and refit the whole sorry abomination. Give me a spin on any day.
raytwntrvlr
Raytown, Missouri
2021 Ranger XL
Thank you for sharing your story. Tough lesson for sure. I know I will be sticking to the OEM when I do my own changes.
I'm wondering if the dealer will do the long block or short block when they put it back together. Also, does this type of major calamity show up in a Carfax report?
Progeny2021
Charlotte, NC
Glad the OP has the situation under control and is getting back on track.
Am I driving the only trouble free Ranger here at 5g (?) - fingers crossed. My previous 3 Rangers were relatively trouble free as well.
I honestly don’t remember the last time I changed my own oil….carried oil/fluids in my vehicle, etc - my motorcycles excluded.
I have had neighbors vandalize my vehicles out of hate/jealously, mostly in the last several years….
Auto insurance rates went up recently, despite my credit score being in the ‘excellent’ range. Carrier stated it was because I opened one too many credit cards in recent years.
Checked around and I’m still getting the best rates from a small, but highly rated company.
All is good….:)
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
I agree with @Msfitoy! Great attitude and probably why things moved your way. And someone will now get the opportunity to own a 2020 Ranger with a brand new engine, so they will be blessed as well!
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I pretty much always use OEM filters. FL-910's were hard to find for a while so a couple times I did buy Supertech which is a perfectly fine filter, or NAPA Gold.
Fram has been garbage for a long time. Motorcraft is a vastly better filter for the same price.
My truck and my daughter's car get Motorcraft.
My wife's Chrysler minivan gets Mopar.
My mom's Cadillac gets AC.
Darn that's to bad and I'm glad it worked out well for you in the end. The Snow Edition is really nice and hopefully you'll enjoy this on even more. I do agree you have a great attitude with this and I know if it were me I'd beat myself up over this for months!
Not a dig at you OP (or anyone else) in any way but this is why I don't change my oil anymore. Sure it's an uncommon mistake but you have NO recourse. At least if it's done through the dealer or reputable shop they're responsible for it. Of course now I'm nervous as I'm getting my oil changed and tires rotated today.:oops:
Guess you found the silver lining and ended up with something nicer than what you had out of all of this.
Long ago I learned saving a few dollars on things like oil filters is just setting yourself up for far bigger headaches. Today I only use Wix, Mobile 1 and Motorcraft. I buy them in bulk from Rockauto online. I get just about 2 to 1 to retail prices. Glad it all worked out for you!
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
13 k sounds crazy high to me , reman long block can't be over 4 k ...
I think I saw like $5700 on a Ford parts site, I think it was a Ford reman. Still a far cry from $13K+.
I think the OP might be able to maybe get some relief through small claims court, depending on his local SCC laws. Many go up to like $20K. If my math is right, he still is out about $10K, would be sweet to have Amazon make good on his loss.
