The elusive cosmetic bumper plug for the spare tire winch
philosopheriam
Anthony
Aurora, IL
2023 Ranger Supercrew 4x4 Lariat, Splash Edition
Heavy Equipment Field Mechanic
See attached photos.
Mine fell out at some point - my local dealer had to submit a request to Ford to obtain this part number, as it is *not* listed in the parts breakdown.
Just in case this happens to you, now you have the part number.
Cheers!
JHC14
Joel
Baker, LA
2019 Ranger Lariat 4x4, 2017 Escape Titanium
Executive Pastor
Ummmm, I don't see the photos
Its there - you just have to know where to find it:
it's listed under - Carrier & Components in the IPC
Item #6
P/N = KB3Z-1543262-A
Lock
KB3Z-1543262-A
Ford
MSRP $35.00
$29.40
ADD TO CART
philosopheriam
philosopheriam
Anthony
Aurora, IL
Item #6
That's actually a lock that Ford sells which fits the same opening. It is *not* the cover I posted earlier. I went down this road with the parts guy.
Hmm, its looks like a redesign has been done - square vs round, I wonder if they addressed the issue of them getting dirt & corrosion inside and locking up.
It appears that P/N: LB3Z-17K922-A, fits the 2024 Ranger, but by visual looks - it works
I pull and lube mine at every oil change, to keep it moving free all thanks to others posting about getting the key stuck in it.
They will seize up on you, if you do not do preventive maintenance lubes on this
philosopheriam
philosopheriam
Anthony
Aurora, IL
The one I posted is simply a plastic cover - you insert it and turn it to lock the tabs. It has no metal, no mechanism.
Stevedbvik1
2022 Ranger Tremor XLT
Did they do away with the locking one on the 23’s? Or does the OP have a 24?
philosopheriam
philosopheriam
Anthony
Aurora, IL
My truck has a build date of 6/23 - it never came with a lock, just a plastic cover.
Ok, I understand now, this (your plug) just rotates and requires (No-Key)
Well, that is is better design, as I do not see many thieves steeling spare tires, even with the locking type it would not take much to force it off.
Stevedbvik1
?‍♂ looks like one of the last 5G discontinued items. Pretty sure 19-22 all had locking ones
Yup another bean counter discontinued item for 2023. My '23 was built on 3/23 and has the plug also. If I'd had know that I would've pilfered the one off my '19 along with everything else I took. ?
I think I actually would prefer the non-locking cover over the Locking one, no fuss over being on the side of the road in the middle of nowhere to change a tire and have to possibly fight to get the spare dropped down.
Especially for those with keyed ignition, imagine getting your only key, stuck in the lock and no way to drive the truck without it.
Trust me on this, I have the Lariat, so push button start and before I started my preventive lubes on the lock, I was able to get my key stuck in the lock, had to fiddle with it to get it to rotate to correct position to get it out of the lock assembly.
So, I can only imagine someone with a keyed ignition in the same situation on the side of the road on a busy highway or in the middle of nowhere.
I believe this would induce various amounts of curse words.
canyonslicker
Andy
2021 Ranger Lariat
65 YO Juvenile Delinquent
Do you care to share which curse words are to be used in this situation?
