Sync 3 v3.4 Build 21020
Tom_C
Virginia, USA
System Admin, Retired
I have never successfully reported an update through the Ford Owner website. I believe if you connect to wifi and manually scan for updates, this will also report the update has been completed.
I wonder what benefit that provides? Does it report possible bugs in the software? If not, I'll probably pass. My wifi in the driveway is weak.
tmcolegr
Todd
Central FL
2019 F150 Platinum 4x4 & 2019 Ranger XLT 4x4
I believe this updates both Oasis and Fordpass which will remove the update from your available Sync 3 updates.
UofMEngineer
It’ll phone home what you’re currently running. If you want potential bugs reported you need to toggle on the diagnostics option in analytics and diag settings, if you’ve got it connected to WiFi. Then if anything happens it’ll send it in. You can also submit generic bug reports from that menu, just make sure you do it as soon as possible after some event happens.
GregsFX2Ranger
Greg
2021 XLT 302A 4x2 Rapid Red Black Appear Package
Management
Tom_C
Virginia, USA
OK, I used wifi and scanned for updates. Now the ford site says I'm update to date.
huckleberry
North America
2019 Ford Ranger Lariat Screw FX4
this is what was available this a.m. when i forced update ota...
Rp930
Denver
After updating I scanned for updates. Now it’s downloading this.
Rp930
Denver
tmcolegr
Todd
Central FL
So after installing this latest update, I connected to wifi and ran a manual scan to prompt the system to recongnize Sync 3 has been updated to the latest version/build and now it is downloading a file that was not part of the update.
Anyone know what this file is for?
Disregard, this question was answered as I pecked out my post from my phone.
Anyone know how long this takes?
huckleberry
North America
mine updated nav at same time. wasn't timing but looks to have taken lil' less 40 mins or so.
my bad, i guess the nav update embedded with the 3.4 update wasn't the most current (?); rescanned and it picked up another...
tmcolegr
Todd
Central FL
My Sync 3 update, without the map update, took 32 minutes.
UofMEngineer
The map chunks are usually are around 1 GB, then it'll need the NAV VOICE pack which is another 1 and some GBs. So, could take a bit depending on your speeds and such.
That's just another piece of the map update. The NAV VOICE pack.
