Sync 3 v3.4 Build 21020
tmcolegr
Todd
Central FL
2019 F150 Platinum 4x4 & 2019 Ranger XLT 4x4
Not sure when this will be available on the Ford Owner Website, but Oasis indicates it has been released for 2019/21 Rangers
No, I don't know what is new with this build
I just hope Ford included all the files with this release
tmcolegr
Todd
Central FL
For my VIN which has Navigation, the update is available on the Ford Owner website and includes 7 files.
Tom_C
Virginia, USA
System Admin, Retired
Downloaded and unzipping now. So, are you saying the nav files should be included? I thought I read that was a separate download.
tmcolegr
Todd
Central FL
No, I am stating my VIN has Navigation, not to be confused w/vehicles wo/Navigation
tmcolegr
Todd
Central FL
Yeah, I tried the OTA update, but not available yet
tmcolegr
Todd
Central FL
There currently isn't a navigation update available. NA 1 19 is the most current
Gixxers
Joshua
2020 ranger
Steelworkers
What does this update improve?
I’ll let you all partake first and report back what y’all find. Curious if this address the pre charging frequencies.
tmcolegr
Todd
Central FL
Looks good. From memory this one will be available OTA as well.
I will be interested to see if the XML file is written to the flash drive after the update is completed. This seems to be hit or miss.
If not, after updating, one can manually scan for updates and this will also report the update to Ford.
Tom_C
Virginia, USA
Updated. XML file was written on mine.
Sync connection problems remain. I have an old Ipod and an Iphone. I can't start the truck with both connected via USB, else the phone apps won't populate properly. I have to remove the Ipod, plug in the phone and let it sync, then I can plug in the Ipod and everything works after that. I can live with it, but it's a PITA.
tmcolegr
Todd
Central FL
Did you report the update and does the Ford Owner website now reflect you have the most current version of Sync 3 software installed?
tmcolegr
Todd
Central FL
I have never successfully reported an update through the Ford Owner website. I believe if you connect to wifi and manually scan for updates, this will also report the update has been completed.
