Sport Mode
Saddle Tramp
Jerald
Artesia, NM
2020 F350 Lariat, 2019 Ranger Lariat, 2017 Honda CRV
Retired Rancher
So are you guys using sport mode to manually shift or are you just letting sport mode do its thing by driving like you would in standard drive mode? I wish it would leave the gear display up in sport mode. It switches to the tach in the left display and removes the gears from the right. That makes it hard for me to manually shift for some reason.
When you have it in manually shift, the gear it is in will be displayed on the left by the tach, which also comes up in manual
Deleted member 773
this is overdrive gearing 101.
if you run higher RPM, you're burning more fuel.
so cruising at a set speed on the highway in 8th gear vs 10th gear will undoubtedly use fuel at a different rate. this is why they get fuel economy numbers that they do with 10 speed transmissions. you're not running such an rpm spread with every shift. you keep the motor in as low an RPM range as you can.
in town, zipping around wanting to throw your ass into the seat at every light chirping the tires at the old lady in the Fusion beside you...who cares about your fuel economy or your shift point, you're trading fuel for fun times.
Wrong, with forced induction, boost levels (a factor of engine load) have a greater effect on fuel consumption than gearing alone (within reason.) Fuel economy comes from maximizing the amount of time the engine is at the intersection of performance and fuel economy, not from strictly the rpm. The use of multiple close ratio gears allows this sweet spot to provide maximum power more often. That’s why you can get away with a smaller engine when you switch to forced induction. I could manually hold gears on my tuned f-250 that had a gpm fuel consumption gauge, holding 6th on a steep hill and flooring it to maintain speed would use up to double the fuel compared to allowing it to downshift and stay in the power band. With ten gears, you are that much closer to the sweet spot at any speed.
Other items that increase the ability of this 10 speed to achieve higher fuel economy numbers are the ability to lock the torque converter right after launch and continue to stay locked during shifts. Gear box rotational momentum is increased too as the close ratios Require less rpm changes gear to gear.
Jimiv123
Dallas, TX
2019 Ford Ranger Lariat, 501A, FX4, Sport Package, Magnetic
IT Grunt
I don't see why not! The shifter isn't even locked in S, you can nudge it right back to D without squeezing the trigger. If you squeeze you need to make sure you don't skip D and go to Neutral.
Oh good! So it's not just me. Was wondering if something was wrong after I got the shifter recall done. Definitely using sport mode more often.
Hounddog409
Tod
Ohio
F150
Which all means higher RMP = less MPG
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
How exactly do you more combustion per minute without more fuel?
With a normally aspirated engine I agree with you....more RPM = more gas. In a turbocharged engine, gas consumption can vary even at the same RPM, depending on Boost. More boost = more gas. Fuel usage is now a function of not only RPM but Boost as well. If you want to maximize your Ranger mileage, you have a light foot on the gas pedal to minimize boost.
Hounddog409
Tod
Ohio
F150
We are talking RPM. No way are you using less gas at 6000 RPM than you are at 2000 RPM.
Deleted member 773
Rpm and fuel flow are not directly related, there is no set ratio off fuel flow to rpm on any engine. Fuel flow is a function of air flow. Look up how an internal combustion engine works, might help you and grey sky out.
Geoff
NYS
Retired Engineer
Yeah, well what about 2000 RPM vs 2500 or 3000?
Boost sucks gas.
Floyd
illinois
Electronic direct injection with variable valve timing. Also Electronically controlled twin scroll turbo charger and injectors which can fire multiple times per power stroke.
This is a complex fuel management system in which RPM is only one factor.
VAMike
2019 Ranger Lariat SuperCab
Irrelevant, since going from gear 8 to gear 9 isn't going to drop you from 6k to 2k
tivct
Dearborn, MI
Tremor, Focus RS
Rotational friction is linear with engine speed. The faster you're spinning, the more drag you have. Thus, generally, higher gears yield better mileage.
But, with boosted engines, volumetric efficiency also tanks as boost increases. So you don't want to keep engine speed too low and boost like crazy. This characteristic is why people tend to complain about their such & such ecoboost not getting the rated mileage. It's because they're always in boost.
This is where the volumetric efficiency "islands" come from, as someone mentioned in this thread. The 10-speed is calibrated to keep you in the sweet spot of speed and load. Injection timing, valve timing, turbo management, etc, make those islands larger.
Floyd
illinois
Those are extremes of course but load is what really matters...
Holding 3000 RPM with a 5000 pound trailer will use more fuel than 3000 RPM with an empty truck.
Also pulling a 5000pound trailer may actually use less fuel at 3000 RPM in a lower gear than it would at 2000 RPM to hold the same speed, since maximum torque is produced at 3000 RPM.
I can't cite specifics under specific conditions because there are just too many variables and we all know generalities are always false.
