Rear Brakes: Fact or BS?
dtech
colorado
I too had a 90 SHO! One of the most fun cars I've ever owned, but yea, the quality of the car around that engine was sad. You didn't mention clutch... I guess you avoided that. Mine failed before 50K.
I now recall mine was a 1991 but same clutch issue, I got mine to last 80k miles, however soon after the warranty expired (12/12 IICR) the locating arm for the shift mechanism dropped off the car , the bolt was cross threaded but at the factory they simply used thread sealant to secure it, the quality of the car was horrendous. I think getrag did the tranny but maybe Ford the clutch.
MarkR
Kentucky
Ranger Lariat
This is exactly what my rear rotors looked like - I replaced the pads and rotors with Powerstop ones and the shudder is gone. I didn't touch the fronts - they still have lots of pad left and no shudder.
Which Powerstop rotors and pads did you go with?
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Those look horrible. I have 83k on stock set. Still good pad life when rotated at 80k. Might be something amiss there.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Rear caliper sliders tend to stick. Same thing happed on mine a couple years ago, they caught it at state inspection. Inner pads were shot but the outers were fine. Got new pads, they lubed the sliders, did not need new rotors. It's been fine since.
Metal Geezer
Metal Geezer
Thom
Fredericton NB Canada
2020 Ranger XLT FX4 Off Road
Although my slider pins were moving “ok”, after cleaning the old lube and re-lubing with silicone ceramic, they moved WAY better.
Rp930
Denver
Regular silver anti-seize works well too
fusseli
EE
maxbottomtime
NE OH
2021 Ranger XLT SCAB 4x4
Took the Ranger to the local dealership for shudder in the rear end. I had looked at the rotors and saw 0 wear on the outboard faces but major wear on the inboard faces and thought I had seized calipers.
I was told by the tech that the calipers were ok and it was just normal wear….all Ford trucks’ rear brakes are like that and I could only expect 50k-60k kilometres.
Fact or BS???
My rear rotors are warped. Rather, they warp under heat. When i start a drive I can get 2-3 hard brakes, but after I'll get a bit of shudder. Plenty of life on the pads, rotor looks fairly clean. Just shit rotors from the factory I think.
I'll be upgrading them when I do my first set of pads/rotors (at 58K miles, still have some meat on the pads).
Which "poop in your punch bowl" did you select when you ordered your Ranger?
1-water in spark plug 4
2-bed leans to one side
3-drive shaft vibration
4-fuel in oil
5-rear brake pad fail
6-clicking under dash
7-exploding tranny
8-DPFE valve fail
9-all of the above
Weird...my pads are still at 8mm all around at 135K miles...
maxbottomtime
NE OH
4-fuel in oil
7-exploding tranny
8-all of the above
7 is the reason I bought an extended warranty. Shudders, delay on engagement, etc. all present at 40K miles. Just hope it shits itself before my extended warranty ends.
4-fuel in oil
7-exploding tranny
8-all of the above
You forgot to add "A run in with Ground Beef"!!
fusseli
EE
4-fuel in oil
7-exploding tranny
8-all of the above
Add EGR DPFE sensor to that list!
