Brakes
Flymac1
Stuart
2019 Ranger XLT SPORT
2019 Ranger XLT brake pedal goes down even with gas pedal. Pump one time after stopped and it feels
Normal , what needs to be done?
RangerBill
PA
Bleed the brakes at each wheel cylinder. This should firm up the pedal.
HotPepperEd
ed
CA
Ranger XLT
Project Manager - Contractor
Has anyone found SS lines from an F150 or an Explorer,.. hell any Ford/Lincoln vehicle where they seem to be readily available that can be used on the ranger brake line connections seem to be pretty standardized im shocked no one has found a goodridge set for an F150 or 250 that can be used on a ranger....?
I just bought a 2019 XLT in pristine condition with 14k miles.. .dialing it in, hate the freekin brakes,..will get the abs bleed cycled soon, but now I read in here its not a complete fix, so now i need to figure out forscan and get myself set up to do it myself if it has to be done annually or some shit to reduce this issue consistently.
RangerBill
PA
Be sure to bleed each wheel cylinder, that is what will give you a firmer brake pedal
