Ranger Keypad
Mustang2Ranger
Garrett
Southern California
Going on 3 months and still working however I noticed this morning, the housing around the numbers are starting to fade with a few white streaks. I’m hoping I can remove it fairly easily and wrap the housing in vinyl and stick it back on. The housing plastic trim seems cheap, I would have liked it painted magnetic. Hmm, maybe I’ll just prep and paint it and call it a day forever with the keypad besides changing the battery.
The cover/housing pops right off without having to remove the double sided tape part
Tracy Bowman
Tracy
Finally tried my keypad out. It WORKS!!!!! Glad to have it. Might come in handy.:)
mURmECH
HI
2018 Raptor, 2019 Ranger
Makes things much easier. I was thinking about how I would disassemble it carefully but if it pops right off, right to the sandpaper it goes.
mURmECH
HI
Pics don’t do it justice, looks much better in person, I color matched it to truck
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Looks great!!
Is it possible to replace the battery after you popped off the top? Any water sealing concerns?
rangerdanger
SF Bay Area
Was this professionally done? Or where did you get the paint?
mURmECH
HI
I like to think my work is professional:), I did in my backyard using a spray can, it’s kind of expensive, I’ve used it for other work, it’ll be cheaper taking it to an auto shop that repairs and paints.
https://www.amazon.com/PAINTSCRATCH...id=1562139662&s=automotive&sr=1-1-spons&psc=1
Looks great!!
There are no water sealing concerns, the rubber seals looks and feel solid like Mustang2Ranger said, as far as the battery replacement, I didn’t see anything from visuals, hopefully someone can chime in on that. I’d like to know if the unit has to be completely removed from the trucks body to change the battery.
Monty
Prattville, Alabama
Honda
Removal is required. Ford says to use a piece of fishing line.
Mustang2Ranger
Garrett
Southern California
Removal is not required to change the battery. The cover can be popped off and the top of the assembly can be removed without detaching the bottom. You just have to unclip the 12 little clips. I used a bunch of small sized paper clips to jam in there and hold the clips open. See post #61, however I did remove it (to relocate) and the fishing line/dental floss route is the way to go for removal
Ford won't replace the battery I don't think, they will remove and install a new one
VAMike
2019 Ranger Lariat SuperCab
Dealer tried to replace the battery on mine. Didn't work, and now that Ford has clarified that this is something they should replace I have a new one on order.
Geoff
NYS
Retired Engineer
No way I'd try and fix one that has already drained the battery. From what I'm reading the short battery life is due to a problem internal to the Keypad circuity and is not a battery issue. But, if my battery lasts 5 years (or so) I'd likely go for a $4 battery replacement than a new keypad.
VAMike
I agree. :) But telling the dealer that you're sure you need a new part for free either because you're sure that's a waste of time or because you've read it on the internet doesn't get far. (This was done before the SSM. I'm pretty sure mine was the first one they saw because they were surprised that it wasn't the same as the F150.)
Geoff
NYS
Retired Engineer
Yeah, I agree much tougher when you're a guinea pig....
Lunchbox88
Logan
Missouri, USA
2019 Ranger SuperCrew FX4
Asked my dealer about buying this and they told me that they HAVE to "install" it and it has to be in the factory offered location. Have you guys run into this at all?
