Oil filter relocation
Living The Dream
Which Fumoto valve fits our truck?
Their website doesn't list the Ranger.
Good grief...I'm 62 and I probably changed the Ranger's oil more than anyone here with 53,000 miles on the odometer...I do have a Futomo valve with an extension hose...that is enough to make the oil change a zero stress event...Yes you will need TWO catch bucket...one for the main oil and another smaller one for the oil filer drain...other than that, this process is hell of a lot easier than any of my other vehicles which requires bringing out my jack and jack stands!!!...and that to me is a major PIA...I so appreciate being able to crawl under my truck anytime without jacking it up period! ?
meistreguy
meistreguy
Guy
Killeen, TX
2019 Ford Ranger STX
Exactly!
If you want at alternative to the Fumoto valve look at the Valvomax . I like the way it seals better. Also American and veteran owned.
meistreguy
meistreguy
Guy
Killeen, TX
For me, I don't rely on the washer thing, I wrap the threads between 5-8 times with teflon tape.
Didn't mean the seal in the oil pan. I went how the valve seals between oil changes and the cap.
meistreguy
meistreguy
Guy
Killeen, TX
Gotcha. It seals awesome. On the valve there is a cloth-like washer but the ball itself seals fine just like any other ball valve.
TOMDEE
tom
niagara falls
2019 lariat
Yes, I just did my first oil change this past Monday. I am looking into this for personal reasons as I am not
I just did my first oil change this past Monday FYI. I have some mobility issues at times and having access to the oil filter from below would make it easier for me. Also put on the Fumoto drain valve so the next change will be easier and more convenient.
CAN YOU PLEASE TELL ME THE PART NUMBER YOU USED WHEN YOU PURCHASED THE FUMOTO DRAIN VALVE AND WHERE DID YOU PURCHASE IT FROM, AMAZON?
meistreguy
meistreguy
Guy
Killeen, TX
Contact Fumoto directly and after you give them your vehicle info they will tell you what parts go to your specific vehicle.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Old thread or not, hell yeah!! I like to here these stories so I know in 30 years there is still hope for me to be a stubborn guy that does his own maintenance! I assume your night vision is suffering though. ?
LOL...I'm 64 now and closer to 100K...that makes round about 20 oil changes...
Rp930
Denver
One ”catch bucket”. First do the oil filter then move it over to the drain plug. Done.
I prefer to do them both simultaneously so there's no trapped oil...
Fumoto for the Ranger's is the F107SX. It is designed to fit in the recessed notch that the OE drain plug sits in.
A regular type Fumoto won't fit properly as there isn't enough room in the notch/recess to screw it in properly.
I have the F107SX, via Amazon, around $31-$32, and it works perfectly. Been using Fumotos on all my vehicles for a lot of years, and never had a problem .
Rp930
Denver
There is no “trapped oil”. The oil in the pan is the oil in the pan.
