Official map update coming soon…. (Sep, 2022)
VAMike
2019 Ranger Lariat SuperCab
The nav system will work indefinitely. Ford may charge for map updates but in the big scheme of things the updates are mostly for points of interest. I have a couple of TomTom units that I purchased in the early 2000s that have not been updated in 15 or so years and still will get me where I need to go.
must be nice. my nav doesn't know about road reroutes and new bridges built several years ago, which leads to some...interesting route guidance.
of course, the update just gives me MEM_ERR01 so I have no idea whether it's any better. I'm torn between saying "screw it" because I always use waze anyway, and wanting ford to fix it just because it's their fault their update process sucks.
Progeny2021
Charlotte, NC
Is your SYNC3 unit turned off for the entire process? It should be - you should only be seeing the default screen of the available functions and a mini map. I just performed my 2nd update - prompts were clear - went without a hitch.
The blinking blue LED on the end of the USB stick will turn off at the end of the process when a prompt will advise the process is completed.
VAMike
ERR_MEM01 is a fairly common problem that seems to indicate that the sync 3 unit has decided there isn't enough space internally for the update. AFAIK once it's gotten into that state it can't be fixed with any kind of wishful thinking involving different ways of playing with the installer, and requires something from ford to fix whatever went wrong in the past (by removing stuff to free up space internally). The thought of dealing with ford support is why I'm leaning toward saying "screw it".
UofMEngineer
Yeah they’d need to send you a special update to run that just deletes the existing Nav files so you can then re-run the map update.
JimJ
Twisp Washington
07 FX4. Level2. 2022 SC FX4 on order
My22 Ranger Owners:
Any 22 owners able to update, map update does not register that my Vin # is valid - I get error code, it thinks that the Vin belongs to something (<2010) and not eligible for update.
My truck was built in Aug 2022, and anything I do that wants Vin # (Ford Parts/Map Update etc) their systems do not register VIN # as valid. Too New I guess
I have Map vs NA20 and fully updated Sync - Installed Now, looking to get updated to NA21.
What is average time for Vin #'s to be Valid in Fords system?
On that note as dealer was not clear:
I know that Sirus XM is good for 3 months (Trial)
But what about Navigation? and it's yearly updates
Same here I received a message on my Ford Pass app. Went and entered my Vin and it said vehicle not covered
VAMike
I really don't understand why there isn't a (hidden?) option that just does that rather than this BS with special one-off update templates that need a support call.
alcohenusa
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
You might try contacting ALOM directly and see if they can figure out why your VIN isn’t working. I have have good luck by emailing them at [email protected].
Include the ESN along with your VIN. Be sure to give them the Sync ESN and not the Sirius ESN.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Same with mine. Just went to update and entered the vin. Got a message that it's older then 2010 and not eligible for update. Something is wrong with fords vin numbers.
SigOris
Greenwood Maine
Retired DoD EE
Same here and I’m tired of playing IT for two Ford vehicles
Progeny2021
Charlotte, NC
I clicked on the link to download the map update, the webpage changed and there was no longer a link to download the license file. I had to pay for the USB stick. Do they need to make this process so convoluted ?
Install worked.
Anyone know how to format and reuse the Sync Map USB stick they send out by mail ?
Windows doesn't seem to recognize it.
I'm thinking the same thing but haven't tried it. Mac OS/Intel at home. Have accumulated two Ford Map Update USB update sticks so far - the 'blue light' is too cool!?!?
JoeC
New England
Install worked.
I'm not sure what you mean that Windows 'doesn't recognize it'.
Yes, it's formatted exFat, which is special, but it should still 'recognize it'.
To turn it into a 'normal' USB, format it Fat32.
Is that what you mean?
alcohenusa
alcohenusa
Alan
CO
Install worked.
The web site only lets you download the files one time so it must have thought that you already downloaded the update. However, you can download it again (free) if you kept the original email confirmation from the first download by using the link in that email.
Figarou
Blue light comes on, but the stick does not appear in File Explorer or Disk Management.
Would that be "not recognized" ?
If Windoze can't find it, then how to format ?
Use Diskpart
Windows 10
Open a command prompt as administrator
Windows 11
Open Terminal (Admin)
Type diskpart
In diskpart.... rescan
in diskpart... list disk
You should see a list of disks and drives on your PC. The USB stick is usually the smallest in size.
in diskpart... select disk and the number of the usb drive in the list. It could be 3 {select disk 3} Again look for the small size in the list. Don't confuse it with your recovery portion
In diskpart.... list partition
here you should see the partitions on that USB stick. If there's more than 1, then you have to delete it one by one. Let's say you have just one.
in diskpart.... select partition 1
in diskpart.... delete partition override.
Do that to each partition. You must select the partition 1st, then delete.
Finally
in diskpart..... create partition primary
USB should work in windows after that. Format it to your liking.
JoeC
New England
Use Diskpart
Windows 10
Windows 11
Type diskpart
Finally
Well, I'll be darned!
MY computer was fooling me.
I also wanted to use one of my old $40 MAP update usbs for this update.
Everything looked good in file manager, BUT it just wouldn't write to the usb!
(It gave an error saying the device didn't exist.)
Sooo, with nothing to lose, I did as you said using diskpart.
And poof, everything now works!
THANKS for your help.
Figarou
I'm glad it worked for you. I forgot to put "enter" after each command. But you figured it out. ?
