Not as good as I thought it was. (MPG)
I thought the same thing when mine was new. Plenty of factors play into your mileage. Mostly you! Winter mine tanks hard when it’s below freezing. I do like to tap the skinny more than I should so that’s a factor for me. Last fill I did 20.5. I’ve had lows at 17 before. You change your driving style as gas gets more expensive too
I think these are the biggest factors in MPG:
  • Driving habits (i.e. - how much you mash the skinny pedal)
  • Winter vs summer blend gas (I typically lose about 2 MPG with winter blend)
  • Temperature (not sure about this one - or it could be the summer vs winter blend)
  • Quality of gas- the "top tier" really does make a difference with this engine - I've used non top tier gas and suffered MPG loss
Cant forget us pansies that use the hell out of the remote start!!
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Mine started to get "promised" numbers around 3500 miles IF I keep my foot out of it.
Go boost crazy or idle the crap out of it and it goes back to doodoo but when I am driving for mpg I am seeing the rated mpg in city and highway, even with the a/c on.
Muffin1
NJ
No, it doesn't get better.
Take off the level and tires if you want it to get better.
Curious as to why does the leveling of the front negatively impact mpg's?
Newbie on this stuff sorry:blush:
Lift kits and leveling kirs affect the aerodynamics of the truck. Depending on the kit will depend on how much it affects it. For example I had the Old Man EMU lift kit. It still kept a fair bit of Rake(the enemy to others here LOL) so it did not impact the MPG as much.
Muffin1
NJ
OK got it, considering the mpg's are a disappointment (to me) i cant imagine they could get worse:( And while i like the idea of leveling and want to consider it, ehh maybe i rethink idk.
halligan1201
Byron, IL
2020 Ranger
Emergency Management
You need a few thousand miles to get an accurate picture. And use an app, don't trust the truck. Not only is it not accurate to begin with, it ignores fuel burned while running during a remote start. It doesn't start counting it until truck is started with the key or push button.
Lol you are incorrect about it not counting fuel used during remote start. When I used remote start(mind you I used the app) the truck had no problem counting that. When I used it quite a bit in the winter my MPG would be between 14-16 for city. HWY would be different for obvious reasons.
halligan1201
Byron, IL
2020 Ranger
Yeah, I use Feulio to track actual fuel used vs miles driven.. Fill-ups with remote start (using scheduled starts) are 4-5 mpg off from truck; truck shows 18.5-19 mpg; actual is 14.5 to 15 mpg. Fill-ups without remote start match truck within .5 mpg. I've done this for three months and have the same result every time. So either the truck coincidentally has terrible on-road mpg during the same tanks as the remote starts or it's not counting remote start fuel burned.. And the drive is the same, gas station is the same. Only variable is the remote start.
Gsd1976
Las vegas
Ranger
Construction
8500miles on a 2021 tremor leveled with 265/70/17
I've never seen over 16 mpg avg on a tank of gas. I can see that it has the capability of doing better when I hit the freeway, but that's a small fraction of my daily driving. I tried 87 octane and 91 which is the highest I can get in Vegas. No change.
Opinion: I don't believe ford's estimate is accurate. For the tremor it was 19 city 19 hwy. I find some of the claims of 23+ hard to believe especially those running 285/70/17 and up. Its most likely someone resetting there MPG before a long stretch of flat on cruise control.
Anyways it's a truck and I'm gonna put bigger tires on it regardless. I came from jeeps I'm used to crappy gas milage.
JasonTremor
2021 Ranger Tremor XLT
Stock 2021 Tremor here. Picked up in November so all winter driving so far. Tanks have ranged between 19.5 and 21 mpg so far at 2700 miles on truck. Best mpg when cruising on 55 mph speed limit roads. Worst mpg traveling 70mph plus interstate speeds. All hand calculated. I don't do remote or scheduled starts, just jump in and go. 87 octane always used.
Lol again as I mentioned before it all depends on the setup and conditions. A leveles truck will not get as good MPG compared to a truck that still has Rake. Also tire weight is something to consider as well. The Firestone tires I ran on my Ranger were considerably lighter to the KO2 and the Grabber ATX in the same size and load range. A lot of things can affect MPG along with a tune too.
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
It's not even broke in yet so don't sweat it just yet. Give it a while and try and stay out of the boost if possible. That will kill your mpg fast! I have a 2.5" level and 265/70/17 tires and I'm averaging 22 mpg.
Dave beat me to it Aldolf. My biggest problem was learning how to drive a turbo vehicle. I found my problem was when starting from a stop I was putting my right foot into the turbo every time. When I learned the art of starting from a stop things got better. Give 'er some time, it should get better for you.
