MBS Extended Automatic Transmission Dipsticks now available
For the same reason you don't change your oil when it's cold. I don't have to change it that hot, of course, but I want to get as much out as I can each time I do it, so It's going to be at least 130° when I do. ?
That sounds reasonable.
HeatXfer
Nor Cal
Retired Pipefitter & commercial HVACR Tech
Probably overkill, but I've got nothing but time to overthink everything!
Stevedbvik1
2022 Ranger Tremor XLT
As I understand it the highest level in the pan is when it’s sat the longest ( cold). So if you’re trying to extract the most fluid wouldn’t that be the optimal time to do so?
HeatXfer
Nor Cal
Thanks for that. I hadn't seen that before. I have Been doing some research and found the 10R80 doesn't have a thermostatically a controlled check valve like other transmissions, so in agreement with your comment, fluid temp shouldn't matter. Just to put it out there ULV viscosity, while already very thin, drops from 19.2@100°F to 4.5@>130°F.
Regnar
Brad
CO
‘21 Ranger Lariat
Next week I will have more up on the website!
Thanks,
I just found out about this mod and checked the site - looks like it’s sold out. No rush at all, but do you plan on doing another batch?
Also thank you in general for all of the work you’ve put into this!
TJC
If I let my truck sit overnight and drain I get ~5qt. If I let it sit 3 days, I get ~7.5 qts out. I change my fluid cold. It does flow slower but that is not a bad thing if you are measuring what comes out.
Easier to stop at a quart levels. And then change the gallon jugs. Tip: Be sure to use the hose clamps to secure the hoses, and use a brass plug on the output hose end to keep it in the jug.
I never spill a drop. Put exactly the same amount in as you took out.
HeatXfer
Nor Cal
Easier to stop at a quart levels. And then change the gallon jugs. Yip: Be sire to use the hose clamps to secure the hoses, and use a brass plug on the output hose end to keep it in the jug.
Thank you! THAT is priceless info! Now I just have to let the truck sit for 3 days (that's harder than it sounds)
I am so appreciative of the invaluable, real world experiences that are shared in this forum. ?
Fitzmotor
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Thank you very much!
I'm waiting on the PTFE braided hose, hopefully soon I will have a 350' roll of it, maybe today, most likely the beginning of next week.
This time it will be a little longer but I'm usually only 3 days between batches, so if I'm out, check back in a few days.
Thanks!
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
This time it will a little longer but I'm usually only 3 days between batches, so if I'm out, check back in a few days.
Thanks!
Well worth the wait. Mike is a first class guy as well as his products and his after sale customer service. Wish there were more merchants like him.
TJC
I wish there were more people like him! Integrity is a rare trait.
helios
james
'19 lariat 501, '21 Lariat 501 tremor
cdl
product looks awesome! now will it work on a '24 RR?
