Lower the noise volume of the turn signal?
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
In forscan you can change it to IPC only. That should quiet it down for you.
I always use full synthetic. Only the best for my blinkers.
You must be rich. I only use the synthetic blend. :frown: But it is Max strength.:muscle:
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Just remove the blinker/flasher relay?
Not sure if the Chime Volume can be adjusted, it does have (2) source outputs.
Normal - Tick-Tock is generated through the IPC and this is the only chime normally sounded through the IPC, the IPC is a backup (if ACM is unable to produce the chime), such as Door Open and Key In Ignition (Not Is Assy or Run Mode)
The IPC = Center Dash Speaker
Left On Chime (Turn left on for more than 2 miles, sound is moved to the ACM (Front Door Speakers)
RCMUSTANG
Ray
Los Angeles
IPC is actually from a small speaker in the IPC.
Gazmic
WA
Machinist
19 Lariat. I have to look at my dash because I can't hear my blinkers. is this something changed in other models?
You are correct, the manuals are vague, this diagram is the only thing that depicts the Turn Indicator speaker is internal to the IPC itself.
Turn Signal On Chime Tone
The IPC provides a repetitive 1-second on/off tick-tock chime tone along with visual RH or LH turn indicators to inform the driver the turn signal or hazard lamp function is on.
The IPC receives the left turn lamp on request and right turn lamp on request messages from the GWM over the HS-CAN3 .
The GWM receives the left turn lamp on request and right turn lamp on request messages from the BCM over the HS-CAN1 .
Turn Signal Left On Chime
The turn signal left on or turn signal minder chime uses both odometer and turn signal status messages. The turn signal left on chime sounds a repetitive 1-second chime through the front speakers when the vehicle is driven with the turn signal on for more than 3.2 km (2.0 miles).
The IPC receives the turn signal switch status and odometer count from the GWM over the HS-CAN3 .
The GWM receives the turn signal switch status from the BCM over the HS-CAN1 .
The GWM receives the odometer count from the PCM over the HS-CAN1 .
When a chime request is received, the IPC sends the IPC chime request message to the ACM to sound the chime.
Troubleshooting Pinpoint Tests, just has you scan for failure codes for an imperative chime.
PINPOINT TEST BP : THE TURN SIGNAL-HAZARD ON CHIME OR TURN SIGNAL LEFT ON CHIME IS INOPERATIVE
Normal Operation and Fault Conditions
See Turn Signal On Chime Tone or Turn Signal Left On Chime. REFER to: Warning Chimes - System Operation and Component Description (413-01 Instrumentation, Message Center and Warning Chimes, Description and Operation) .
Possible Sources
  • Turn signal indication concern
  • Communication concern
  • BCM
  • GWM
  • IPC
BP1 CHECK THE SEATBELT WARNING CHIME OPERATION
  • Ignition OFF.
  • Ignition ON.
  • Unbuckle the driver seatbelt.
  • Monitor the seatbelt warning chime when the ignition is transitioned from OFF to RUN for 6 seconds.
Does the seatbelt warning chime operate for approximately 6 seconds?
Yes
GO to BP2
BP2 CHECK THE TURN SIGNAL INDICATOR OPERATION
  • Verify the RH and LH turn signal indicators operate correctly.
Do the turn signal indicators operate correctly?
Yes
GO to BP3
BP3 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS)
  • Using a diagnostic scan tool, check the GWM Continuous Memory Diagnostic Trouble Codes (DTCs).
Are any Diagnostic Trouble Codes (DTCs) recorded?
Yes
REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing) .​
No
DIAGNOSE all BCM Diagnostic Trouble Codes (DTCs).
REFER to: Body Control Module (BCM) (419-10 Multifunction Electronic Modules, Diagnosis and Testing) .​
