Looking for a bit firmer suspension, what is next?
Glocker
Boca Raton
Just ordered ABS plastic sheets, JB Weld plastic weld, JB Weld plastic putty, and Bondo plastic filler for the fender flares. I will start an @OFC Ranger inspired mod thread for them soon!
OFC Ranger
OFC Ranger
Jack
ZR2
Wow holy crap. I guess it was like a boiling water affect, as time went on I added more and more gear I failed to pay attention. The only downside is my tallest roof trunks are about 2" too tall to fit through the garage door now. lol
Oh well.
I also opted to keep my 1" eibach blocks installed because unlike most, I will be retaining a constant heavy load in an almost permanent configuration. Now I retain my 1+ " height in the rear when fully loaded instead of a bit of drop from said load even with the leaf helpers in.
Also gives me a very small rake, which I actually prefer in this setup.
Pictures say it all, shesh.
Oh well.
Being fully loaded it is ok to be level or have small rake. That is the purpose of a truck having rake in the first place.
Wich helpers did you get? Also with all that weight how is the ride with the new helpers installed?
OFC Ranger
OFC Ranger
Jack
ZR2
I went with autospring. Pair of 750lb helpers was $260. Install is just drop in between top leaf and bottom overload leaf.
Small jaunt after install; My poor eibach felt like factory shocks with all that weight. Much better now.
OFC Ranger
OFC Ranger
Jack
ZR2
So after action report after doing about 300 miles round trip over the weekend.
Not much to say other than everything is just flat better. I am now back to properly floating over uneven terrain instead of bouncing over it. Truck seems to handle much better on the highway as well, though not sure if this is a placebo effect or a mixture of both.
No creaking or squeaking either, but these helper leafs did come with proper coating and teflon contact pads, like all should I imagine.
glad you like them. I felt like they were a big improvement on my ranger as well. much more secure feel now instead of the floaty boaty feel on bumps.
Glocker
Boca Raton
I find the rear of my truck tends to bounce more and jar whatever is in my bed with the add-a-leaf. It's a bit annoying, but I'm not reversed raked and it handles weight well. It was key back when I had a boat I was towing to the boat ramp too.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Would the Sumo Springs be any help for this?
I've been distracted and haven't installed either the Sumo's or the Euro springs. From a street handling perspective (and my personal speculation) I expe t that independently the Sumo's will make each rear spring more 'progressive' due to their inherent design and in the case of an unladen truck improve handling.
Tweaking the rear still begs addressing the front and in the absence of a modest swaybar upgrade I'd still like to firm up the front a hair, especially since I've raised the front with the Eibachs. There are heavier duty end links that 'might' stiffen things but in the past I've found changing the swaybar-to-frame bushings to stiffer urethane doesn't introduce extreme (dangerous) loss of traction.
A stiffer front bar:
1. Decreases front chassis roll.
2. Decreases front grip or traction, while increasing rear grip or traction.
3. Faster steering response.
4. Decreases off-power steering at corner entry.
I believe other experienced members have expressed caution at randomly changing the factory design but I'm looking at subtle improvement IMO.
Not radical stuff, but I haven't found replacement front bushings.
OFC Ranger
OFC Ranger
Jack
ZR2
Anything altered out of spec is going to to have some level of risk.
Different offset wheels? Danger
Wheel spacers? Danger
Different Suspension? Danger
Tuner? Danger
Non-motorcraft oil filter? Danger
Relocating front cruise control radar? Danger
Blah Blah Blah
There are always extremes in everything, like a 1" wheel spacer vs. a 10" brotruck wheel spacer, but some people only see black and white.
Heiserton
Logan
Missoula
www.3dproto-lab.com
2022 Lariat Ranger Tremor
Aviation
I've installed Sumo Springs and Hellwigs on mine just a couple days ago, have about 500 miles on them so far and the Hellwigs will probably come off. Probably overkill with them on, but I think the Sumo springs would suffice on their own.
jflogerzi
Moreno Valley, CA
Its users like you that make this community what it is. Thanks for the report and love the truck. I wonder if the wildtrack springs would have done something similar?
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
It's been a few months since you installed the Auto Springs and I wondered if you're still happy you went that route.
Question for you and others:
I have a '19 4x4 Lariat with a 1434Lb payload limit but I will be getting a Scout Yoho camper weighing in at 1100 Lbs. The camper isn't going to be on the truck 100% of the time (maybe closer to 50-50). My first thought is airbags. But I'm also wondering about the Auto Spring add a leaf. That would increase payload capability and I think it would be pretty helpful with an 1100 Lb load (in addition to airbags) but what is the ride like with no cargo? (I don't want to be bouncing down the road...lol ).
Alternately I also considered a Hellwig helper but that solution means no airbags.
Lastly new springs is an option but I'm not ready to take on that expense at this point and see no point...I will not be doing any off roading with the camper on.
Racket
Here and There
Transient
I'm no expert or super experienced person on this but after communicating with @Grumpaw I'd consider the Roadmaster independent rear suspension kit before the Hellwig. The costs are sort of in the same ballpark but I believe the Roadmasters are going to be safer in emergency maneuvers on an unladen truck.
I've put on the Ford multileaf springs and Sumo blue bumpstops and while I haven't tested any emergency type handling I haven't experienced anything that would cause me concern yet. I still would like to fine tune the front a little as I think the rear has a better range of control.
My only reservation about the Roadmasters is adding complexity to the rear suspension.
Geoff
NYS
Retired Engineer
Thanks for the thought on the Roadmasters. I'll check it out.
Reactions: EJH
Crow_of_judgement
William
20 ranger screw lariat
Was the decked setup worth the coin? I've been eyeing it mainly for pew storage while traveling to and from the farm
