Livernois tune update
Jmarler
Jmarler
Jimmy
San Antonio
2026 ranger raptor
Certified Hacker. Retired Veteran
That's why I was afraid to switch over to the newer version. I'm happy the way it is now so like the old saying goes "if it's not broke don't fix it". :D
It did fix that noise problem I had though
Don’t waste youre money. give me $625 I’ll kick you in the dick and give you back $325 I just saved you $300
Hard pass, but thanks!
Man I think my truck is night an day better with the 93 performance tune. I run the 87-89 tune in the winter an it's much better than stock too.
You run 87-89 on a 93 tune?
Langwilliams
Langley
Lorain, Ohio
How long did it take for the tune to settle in? It's driving me nuts with the transmission relearning.
Not that long for me. I commuted in it every day when I added the tune an I liked to floor it to hear the tires chirp on the shifts so it got broke in fast.
Langwilliams
Langley
Lorain, Ohio
No for winter I put the 87-89 tune in. My thinking is with slick roads an snow there's no need for the extra HP. This spring I'll put the 91-93 tune back in. You can feel the difference between the two but you can feel the difference between the stock tune on 93 an the performance tune on 87-89. Better performance an cheaper gas.
Honestly you could save yourself a bunch of headaches by installing the tow tune and simply switching octane as needed. Then you dont have to worry about the transmission relearn process either.
Langwilliams
Langley
Lorain, Ohio
Since I've retired I've been staying in more an only buying gas every 2 or 3 weeks instead of every week so I may just stick to the 91-93 tune. Another reason for the lower octane tune was to save that $.60 a gallon for a while until I see how things go on my retirement income. I'm using so much less gas not driving 30 miles a day for work it's not a factor.
Aonarch
Alec
North GA/ Montana
Yes but I am curious about what level or error is built in. But if I were to do it I have 4 5 gallon jugs. Fill them up and store in garage and get a testing kit to insure I knew what mix level was needed. Only do it when I wanted to have some fun :p
Ethanol is not shelf stable though, and what you get out of the pump is in the E50-E90 range. Hence why they say you need to test it first. For me E30 tunes are for Dyno brags.
Jmarler
Jmarler
Jimmy
San Antonio
2026 ranger raptor
I've been driving with the performance soft tune 93 version 4 for awhile and it's doing extremely well. No harm in updating if you choose to do so.
CO2Ranger
Same experience here. Its been smooth sailing with V4.
Jmarler
Jmarler
Jimmy
San Antonio
2026 ranger raptor
How do I check what version of stock tune I have? Plan to return it to stock for 10k maintenance check and oil change.
If anything you just flash back is all but in my opinion I say just leave it unless you know it needs to get flasged for a check engine light issue or recall. Other then that you should be fine.
One thing is for sure when I had the stock tune and you push the tow mode button you physically could not make it go onto 10th gear with no load on the truck. Pressing the + button it would stay at 9th.
Incorrect.
Unloaded, tow mode will shift into tenth at roughly 75mph.
jflogerzi
Moreno Valley, CA
Its good for a certain period of time. Keeping moisture out is key.
