- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,482
- Reaction score
- 8,548
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I know its been done with the TBC install to access the CHML.
I think you should be able to just lower the rear section by:
Pulling the Grab Handles
Pulling the Seat Belt Retractors and (C-Pillar) Panels
Then drop the rear section of the Headliner via 2 clips
This should allow enough room to inspect but if you need to pull the Trim Rail and reseal the mounting (attach) point - there may not be enough flex in it without pulling the front as well.
Hopefully it will flex enough to add some sealant at that mount without having to remove the front attach as well.
I am sure its leaking from the rear attach point (stud) on the roof trim (Posted Above
Of course I've never dealt with a leak before either.
