I have an ‘19 XLT and have had a leak for a while coming down the left A-pillar on to the floor. The last downpour my son in the back says his leg just got wet. It was from the right B-pillar. Got up and looked to see if I could find anything and noticed cracks at the roof seam at the back. Disappointed no end.
Before doing prep on my window trim, I decided to clean and wipe the interior down. While I wiping all the plastic down (with 303 of course) I noticed this.
I'm guessing its the seal on the back window? At least I'm hopping it is, and not the roof seam.
It also could be coming from the CHMSL...I had replaced mine with an aftermarket unit and it didn't seal very well...same result...
You can try the test I just posted to confirm the crack is your leak (probably is ) and post your results here. I'm going to try to do the test this weekend and I'll post my results when I get them.I have an ‘19 XLT and have had a leak for a while coming down the left A-pillar on to the floor. The last downpour my son in the back says his leg just got wet. It was from the right B-pillar. Got up and looked to see if I could find anything and noticed cracks at the roof seam at the back. Disappointed no end.
Center High Mounted Stop LightCHMSL... ?
I have used this type of test in the past on other vehicles. however used my smoke machine vs soapy water.Well now that I'm done dealing with the trim and ground squirrels its time to get back to my leak.
I like to try to diagnose my issues before taking in to the dealer. Was going through the service manual that showed up here awhile back and found this.
501-00 Body System - General Information 2019 Ranger
Diagnosis and Testing Procedure revision date: 05/4/2018
Body System
Symptom Chart(s)
Diagnostics in this manual assume a certain skill level and knowledge of Ford-specific diagnostic practices.
REFER to: Diagnostic Methods (100-00 General Information, Description and Operation).
Dust and Water Leaks
Most dust and water leaks occur due to missing or incorrectly installed body sealer or components. The
source of the leak is detected by:
• pressurizing the vehicle and testing with soapy water.
Locate and tape off the body vents.
Turn the blower motor to HI.
Turn the air recirculation OFF.
Close the windows and doors.
Open the hood and spray soapy water along body seams and grommets. Make sure to test the
areas around the A-pillar at the fender and the hood hinge area.
Check for bubbles.
Has anyone tried this approach to find a water leak and did it work?
I plan on trying it anyway, just wanted to know how others fared.
If it is leaking from here then the rain water is most likely dripping off of the rear attach stud under the headliner.I have an ‘19 XLT and have had a leak for a while coming down the left A-pillar on to the floor. The last downpour my son in the back says his leg just got wet. It was from the right B-pillar. Got up and looked to see if I could find anything and noticed cracks at the roof seam at the back. Disappointed no end.
I do, but I don't want to go without my truck for a day and then pay diag or the detectable when the dealer says they couldn't locate it. When my truck goes down for a repair I can't afford to chase a problem that may cost me a days pay if the wife needs her car for the day. Besides I used to do most of my own work on my vehicles and enjoyed it. The way the tech is these days just seems like a requirement to get an extended warranty.Still have the warranty ?
That's strange because I've always foamed and power washed both my rangers and never had this problem. There has to be a fail point somewhere in that channel because like you I rinse that area a solid 4-5 times until the soap stops running out from there and have never had any leaks. I try to stay a minimum of 12'' - 18" from the body when rinsing so we're both within the same distance.Well I washed the truck yesterday with the pressure washer and my leak showed back up. I paid attention to how far I was holding the wand from the truck and it was 18" to 20" on average from the truck. I did spend a lot of time with the sprayer on the gutter to get all the soap out, and still wondering if this is my problem area.
When I did a pre rinse to get off any large pieces of grit and dirt I checked the headliner and it was dry. But after wash and rinse it was done it was there.
So I want to drop the headliner part way to see if I can find the source of the leak.
Does anyone know if you can pull down just a rear corner of the headliner without taking the whole thing down?
A step by step from a shop manual would be nice?
Thanks for the help 5g crew.
