I am done with Ford ranger
Josebd
2021 Ford ranger xlt
Road maintenance county
Changed the oil at 4127 miles,because the level was already coming up and smelled like gas,put 6 qts in it which put it a hair below the top of the hash mark on dip stick,now at 1052 on the fresh oil it’s right at the top hole is which is the maximum oil level!
so sad for such a nice riding pickup
JesseS
Jesse
NorCal (Roseville)
I am keeping an eye on mine, it was a hair below the top hole when new, now at 1000 miles it is still in the same spot. I will keep an eye on it and change the oil at 3K and get it tested. I have a slight gas smell but as the level hasn't changed, and everything else is spot on perfect I am not to worried.
CO2Ranger
Just did my second oil change @ 6k on my '21. Put 6qts in on the last change and pulled just a tad over 6qts out. I'm not sweating it, but I did go back to Mobil1. Castrol full synthetic was giving me a slight rattle @ about 3.5k RPMs.
Side note: My 2019 also lost the gas smell around 9k miles which is also when I switched to Mobil1 Extended Protection. Could be coincidence, could be timing. Could be that I worried too much about something that had no real impact on the truck at all...
GA
Ford apparently doesn't talk about this much but they are assuredly aware of it.
Take it to the dealer and have them confirm.
My truck had the fuel in oil issue.
They changed oil and filter and then scribed the dipstick.
I drove it 1000 miles and brought it back.
They confirmed that the oil level was rising.
They did some impressively thorough testing and found that my HPFP was leaking.
HPFP replaced at ~4200 miles and the oil level has not risen again.
Josebd
I do use Mobil one advanced full synthetic oil,I’m waiting on the dealer to get back to me where I bought it,if they don’t want to address it then I’ll trade it in on something else
CO2Ranger
Not saying this is the problem, but if I recall, only Mobil1 Extended Protection and Annual Protection(?) fulfill the spec laid out by Ford.
Floyd
illinois
to the full mark is 6qts and a cup.
Just curious ...
Is your truck stock?
Is parked outside?
Crown Forklift Technician
So just having it move just a hair(especially if you didnt drive it before checking it the second time) then it is considered normal. How you ask? Well the oil has to take time to settle. Thats why. Now that doesnt mean dont have the dealer look at it as it is well worth checking. As for trading it in without giving ford a chance to look into the issue and resolve it is simply a bit extreme on your part. Give Fors a chance. If they become a problem then you can justify trading in or going to a different dealer.
docarter
Dayton
GA
Cadillac ATS; Ford Ranger
ADA
This is absurd.
Gas cannot and will not dilute the oil in any meaningful amount. The heat would immediately turn the gas into vapors which would get burned off by the PCV system.
If you really believe there's gas in the oil you are a moron, sorry. Get the oil tested by Blackstone or another laboratory.
Doc
Doc
Live oak fla
This is absurd.
Rather harsh there friend, there are multiple Blackstone reports on here with gas dilution.(and in a meaningful amount)
docarter
Dayton
GA
ADA
The 2.3L is in what, maybe 500k vehicles now and there are no class action lawsuits or other TSBs for fuel dilution?
The nature of gasoline is that it is barely a liquid at room temp, at the 150-200F that oil reaches, it would instantly vaporize. The PCV then routes that vapor into the intake where it is burned. It's really simple if you understand how the compounds act.
Maybe I was too harsh, but absent a leak in the HPFP casing which could then send gas straight into the block as was stated above, or faulty injectors, no way oil dilution is occurring.
RedDakooter05
Illinois
2022 Ford Ranger STX RWD
Before calling him a moron, take into account that it could indeed be faulty injectors or the casing.
Don't call people morons then proceed to open holes in your condemnation.
Josebd
It did more than just move a hair,it moved from the hash mark to the maximum level in 1052 miles!
Josebd
Stop touching your dipstick and just drive the thing :LOL:
So another 1000 miles it’s going to be way past maximum level on the dipstick,that’s normal?
