HELP!!: My wife bought me Unrequested Ranger Parts - Need Installation Advice.
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
The part in question is this: Nilight TR-04 Truck Tailgate Bar 60" Triple Row 504 LED Strip with Red Brake White Reverse Sequential Amber Turning Signals Strobe Lights,2 Years Warranty
It connects to the Ranger with a 4 pin trailer wire and a fifth loose wire for reverse lights.
Since when do 4 pin harnesses not have a reverse light? I always thought that was part of the deal?
A - Ground, B - Left (turn / brake), C - Right (turn/brake) and then D was reverse. Did something change when we went with all digital LED lights?
Any way.... Here's my quandary.
How do you install this thing? According to the instructions I plug it in to my trailer light harness and leave this unsightly plug hanging out there. Then I hack the reverse wire somewhere and put the extra fifth wire on it.
1. I do not want to put in a cool light bar and then have a towing pigtail poking out under my tailgate.
2. I do not want to have to hack into a wire for reverse. It defies and defeats the purpose of waterproof plugs.
Is there a better way to install what I have? I don't mind purchasing an adapter that goes behind the bumper and hooks into a wiring harness. That's how I added trailer lights to my 93 ranger back in the day. Walmart sold it for like $10. You unhooked a harness from the main and then this add in harness sat between the main line and the rear harness. Worked out BEEEEE-YOOOO-tifully.
Or a different option. I've got $45 sunk into this light. Getting an adapter to make it work is probably another $20 to $40. Is there a Sub-$100 light kit that is as good / better than this one that installs easier? If so I can return this and just get that one.
DangerRanger8721
Drew
Pa
I don’t know how invasive it would be but I suppose you could tap all the wires into their respective wires on the truck like the reverse wire. I wouldn’t want that plugged into the 4pin trailer connection all the time either. Plus I’ve read that mods plugs into the 4pin will cause the trailer blind spot settings to pop up every time. Not sure if that can be disabled
myothercarizahearse
Cleveland, Ohio
Unretired
I'd wire that reverse light with a switch in the cab for those tailgaters. I'm sure that would make them back off real quick at night.
AzureRanger
2006 Jeep TJ
Or blind them and they plow into your rear.
JimJ
Twisp Washington
07 FX4. Level2. 2022 SC FX4 on order
Flat 4 never had reverse lights, flat 5 do have reverse as the reverse signal also opens a solenoid on the trailer so you can back up if you have surge brakes.
Word of warning here. The way our system is setup if you use the plug for towing connections your truck is going to think a trailer is attached (increased resistance load) this will be true if you splice it in as well. Can also cause hyper blink for the same reasons. The only way for this not to happen is to use special relays (opto electric) to keep this from happening.
There are other threads on here that cover this in more detail and other users experiences
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Explain to your wife your truly appreciate the great gift but it will be difficult to install on the Ranger so you will be happy to return it and get something you want. Then duck! :idea:
I agree with pretty much all the replies including the ducking part. Putting tailgate light bars on our trucks is PIA.
Yes our tailgate is I believe only 54 inches long. Also many people have found the clearance when the tailgate is open hits the bar.
Now wiring is a whole nother can of worms. Especially if you have the tow package, LED tailights with BLIS, and rear parking sensors. Plugging anything into the trailer connector will tell the truck a trailer is connected and disable the rear parking sensors and cross-traffic sensing and will mess with the BLIS settings. People have had issues with using a lighted hitch cover.
I believe the only way some people have gotten it to work is by using a 5 to 4 trailer light isolation module spliced into the taillights.
I see some trucks with them and think they are kind of cool. Then I remember it's way to much work for a couple of lights
SigOris
Greenwood Maine
Retired DoD EE
Here’s a suggestion: use a couple of alligator clips and connect to your 4 pin socket and see how things behave. I have the TOW PKG which gives me the seven pin. I used this method to see what happened when I connected some LED fog lights to use for extra reverse lighting. I had no issues so I tapped into the reverse wire and things are slicker than a 303 polished @AzScorpion damper ?
GTGallop
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
CONFIRMED - I plugged it in and Truck thinks it has a trailer.
Shipping it back. That's a deal breaker right there.
That may work if only tieing in reverse lights. I think it uses the brake light circuit to sense the trailer. I usually need to tap my brakes to get it to sense my trailer, turns may do it too, haven't tried that. They are the same filement on the trailer.
