- First Name
- Dave
- Joined
- Jul 25, 2019
- Threads
- 342
- Messages
- 27,112
- Reaction score
- 137,189
- Location
- Back Home In AZ!
- Vehicle(s)
- 2023 Ford Ranger Tremor
- Occupation
- Retired...Full Time Slacker
I've found that right around 2000-2200 rpm is the sweet spot for this motor and efficiency. As you said though once you start to put a load on it the mpg decrease but if you can maintain a consistent rpm you will get good mileage.Going back to MPG, I also have two questions:
1) Is there an RPM range where the engine is most efficient wrt. gas consumption? I think saying "drive XX mph gives you best result" might be a misnomer, since it doesn't account for hills / load. But steeper the climb, or heavier the load, the RPM would go up for the same speed, so maybe a RPM range would be a better measure?
2) Octane Number. People ask me what gas I use, I say "car says regular", then they are shocked, "regular in a turbo"? "The intertubes" say that octane number is only for knock, and not for energy stored:
so how would better gas make a difference?
thanks for taking time to explain!
Regular is what's in the manual but the ecoboost does run much better with premium. I noticed a difference once I switched over and running the 91-93 performance tune has actually increased my mpg by 2 as long as I drive it normal.
