HELP. Just did my plugs
scotthagg
Scott
Groton MA
2019 Ranger FX4
I just did mine yesterday at 60K miles. I'm having a hard time seeing how you could bolt down the coil with the plug boot askew. Did you torque the plugs to 106 in/lbs I hope?
Snug, but can easily go back and torque them. Thanks for the heads up
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Don't want to jinx it. Replace heated seat and did trans flush. Other than that things have been excellent. Lots of Highway obviously. I put Eibach suspension on it as well and changed the differential fluid. Lookingfor recommendations. Should I do the timing chain/belt(imagine its a chain)
Not sure on the timing chain/belt, above my pay grade. I've only broken one and that was in a 73 Capri.
scotthagg
Scott
Groton MA
2019 Ranger FX4
106 IN.lb ; you get close to the spec by simply hand tightening them. My torque wrench barely turned until it clicked.
Ahhh..inch lbs not ft lbs.my bad. I wa starting to think someone wanted me to bust a spark plug
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I'd say the hose that holds the fan electrical harness in place would be a high priority.
Update. Boot 4 was not seated properly, some boot lube and all fine. Thank god. Now I can be honest and tell you those plugs lasted 160K!!!
Was about to tell the same but glad you figured it out...
FYI, I checked mine this weekend when doing all my maintenance and mine is 100% fine.
Racket
Here and There
Transient
Mine looks good too. I imagine most do... until they don't ?
Maybe - but some of the postings I've seen seem to indicate that hose is pretty wimpy (thin walled)- I felt the hose on mine and it felt very strong - wondering if maybe someone thought they could save 50 cents on a piece of hose and replaced it with something wimpy at some point?
