Racket
- First Name
- John
- Joined
- Jan 21, 2020
- Threads
- 23
- Messages
- 2,266
- Reaction score
- 3,598
- Location
- Here and There
- Vehicle(s)
- 2019 Lariat Supercrew 2WD
- Occupation
- Transient
After some searching and buying some bushings, I settled on Superpro greaseable for the front eyes. Took a couple of weeks to get them from Australia. Since I already had the ARB/OME greaseable rears I just stayed with them. If I could start over, I would buy the complete kit from Superpro. I like how the grease fittings are protected by a recessed bolt head. If you have an air chisel the front stock bushings come out quick.
At $230 it seems on the high end of expense. I wouldn't question the quality - Dobinsons looks the same quality but $100 for the bushings, $90 for the shackles and even that seemed excessive for me.
For the moment I'm leaning towards the Dobinson bushings and six grade 8 RockJock greasable pins with the factory shackles. Something around $150.
It would be nice to have a specific kit for the truck but the $100 difference justifies putting it together myself.
There are less attractive designed bushings and cheaper kit components but I'm not as confident in the overall durability for my use. The SuperPro recessed grease pins are definitely a desirable feature.
I'm not going offroading but the intermittent towing/hauling and the truck being a daily driver is guiding me.
EDIT: I don't know if I can swap the pins in the factory shackles yet. Gonna have to crawl under there and look.
DOUBLE SECRET EDIT: the factory shackles can't be modified but the $90 greasable Dobinsins are available for US spec.
(See Phil's comment below)
