- Banned
- #571
I agree any fuel in the oil causes dilution and yes to some extent some fuel may make it's way into the crankcase for a variety of reasons and a properly running engine will absorb that minuscule amount of fuel as mentioned but like I said if there is no increase in crank case oil level there is no fuel in the oil. If raw fuel is getting in the crankcase past the rings during the combustion process your engine has issues. I've never suspected blow by as the problem on this engineI agree with everything your saying... except... "I never had fuel dilution".. every internal combustion gasoline motor experiences it on some level.. It just normally not excessive, but it is always there.
Any fuel in the crankcase causes fuel dilution. This happens especially when the motor is cold. Once the motors comes up to temperature then the fuel, and any condensation, turns to vapors and are typically evacuated from the crankcase by the PCV system, if your vehicle has one.
My point is.. fuel dilution happens, it in itself is nothing new. The issue the folks are having is something other than the normal blow by.
Ford is working their way through the issue, and it appears they are finding it is high pressure fuel pump or injector related.... not blow by related.
As I said Ford will get this sorted out. It's the price you pay for buying new(ish) technology.
