Fuel in oil engine build date
Tra1969
2022 Ford Ranger Lariat Tremor 501A and Tow
Senior Manufacturing Supervisor
Redacted 13
Northeast USA
2020 Ford Ranger Supercrew XLT FX4
Semi Retired
Aug 11, 2020
1800 miles
Oil level is staying steady
Oil has just the slightest smell of fuel
I will keep an eye on it.
Aug 11, 2020
1800 miles
Was that taken on a cold engine? Looks a little high, above the top hole. Should be down in the hashed area
Redacted 13
Northeast USA
Semi Retired
I will agree with you on that. It was still a bit warm from when I had it running.
I was surprised when the instructions say to let it sit for 15 mins before checking the oil (after letting it get up to operating temperatures) - copied from the owners manual:
Switch the engine off and wait 15
minutes for the oil to drain into the oil
pan. Checking the engine oil level too
soon after you switch the engine off
may result in an inaccurate reading.
Mine has been at the top hole since day one. Never changes & that's were I keep it.
My understanding is the top holes is the max fill point and the normal range is the hatchmarked area. Lower hole the min level.
Blue Streak
Larry
Every vehicle I have owned the dipstick had a full mark & a low mark. The full mark was always obviously full, low mark meant you need to add. Any wear in between was usually safe. To me safe is full, max protection, not over or under. Generally with the older cars if you have one that is on the low mark & add a quart it was always on the full mark. I have not had to experience that with any modern cars. Just my 2 cents worth. I know don't buy much nowadays.
JACER
Plant City, FL
Retired Firefighter
Build date of 8/19. Currently at 8400 miles. Had an oil change beginning of November. Oil level at fill mark. Never hss deviated. No smell of gas.
Mr.Scary
Ontario
2019 Ranger sport 4x4
Heavy equipment operator
Engine oil will expand when hot. Not as much as trans fluid but it will if your checking it when it’s hot it will show higher levels then what it is.
also if anyone is having their oil changed at a ford store. Just keep in mind dealers will pump an even 6 litres and call it done as the ranger takes about if I remember exactly 5.74 litres. I do the same when I can’t my oil 6 litres of amsoil and done.
Mr.Scary
Ontario
Where do 6 litre and 5.74 litre fills appear on the dipstick ?
Look in your Manuel your oil fill levels with and without filter are in the capacity section
Dmc
Deb
Oxford pa
2020 ranger
Here is my 2020 with 3400 miles sure it has fuel in the oil yahoo ford ? Just goes with my rusty frame and cross members eng build date 02/05/2020
