Free Sync 3 Navigation Map Updates (NA 1 18)
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
For those of you getting the missing license file error and are sure the file is in the correct folder, check to be sure you have the correct license file. When I first downloaded I got an old license file with a different file name. When installing, I got an error for no license file because of the name mismatch. They even sent out some $40 USBs with incorrect license files.
You can open the autoinstall.lst file with any text editor such as notepad and look at the list of files it is looking for. If the license file you received Is different than the one listed, you probably got the wrong one.
Ford’s recommendation was to clear the browser cache and re-download which worked for me.
Rickfar
Central Pa. Harrisburg/Enola 17025
2019 supercrew sport
So I have downloaded the files did everything I was supposed to do stuck thing USB drive-in it says it's updating the system at seem to reboot and it said the system was updated but here is my problem before I started the update I was that map version 117 and after it did the update and still says my Mac version is 1 1:07 a.m. I missing something or what am I doing wrong? My sync version is 3.3
alcohenusa
Alan
CO
There is an issue where the displayed map version may not update to the new version that successfully installed. Be sure that you are letting the system fully update and not removing the USB too soon. There are multiple ‘completed’ messages and restarts. Mine took about an hour to complete.
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Emissions testing supplier
Sync 3.3 doesn't show the correct map version after the update. You'll have to update to 3.4 "unofficially" or wait for the update directly from Ford.
Dan Keil
Dan
Decatur,Il
2019 Ford Ranger XLT 4X4
Walmart Associate
II have on my thumb drive File name 19Q1_NA_Post-3.3 2ND Release>Sync My Ride.
Then the files are labeled the 15 that on on the TD 4UST-14G421-cac tar
Dan Keil
Dan
Decatur,Il
Walmart Associate
I don't have that!
Dan Keil
Dan
Decatur,Il
Walmart Associate
The order I have on my thumb drive it is:
Stncmyride
Auto Install
DONTINDX.msa
chasvs
Tampa
Tried Waze? Can use it with CarPlay. Been using it for several years before I got my Ranger. I like it a lot.
Tried waze, prefer Google Maps. Hoping Apple Maps is going to be update as they claim in the next rrelease!
aslusers
Indianapolis
2019 Ford Ranger XLT Orange SuperCrew FX4 Trailer Tow 302A
I love Apple Map and it is much further advanced than Ford Navigation system.
aslusers
Indianapolis
Dan Keil
Dan
Decatur,Il
Walmart Associate
In the USB root directory ?
What did you mean above by " II have on my thumb drive File name 19Q1_NA_Post-3.3 2ND Release>Sync My Ride. " ?
That was the file Ford sent me!! The order of things I have on my thumb drive is what I put on my other note
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
This video explains how to save Favorites...
SYNC® 3 Navigation: Advanced feature
Yes, thank-you but I was aware of all that. What I meant by saving favorites was writing them to a USB Drive (or some such). A Master reset erases those saved favorites and there is no way of restoring them hence it would be nice to be able to save them on a USB Drive (for example).
SymChris
Mississauga, ON, Canada
2019 Ranger Lariat FX4 / 2017 Escape SE FWD
I also verified that the Speed Limit ID part still is not accurate. I understand that while the camera sees the speed limit signs, it's the map that knows the speed limit on said sign. Any ideas?
What is this Speed Limit ID thing?
The Ford maps are what show the speed limit is based on prior mapping data, not a camera, that I’m aware. I can confirm this because they reduced some speed limits around me and the map shows the old speed.
CoastieN70
Travelers Rest, SC
2019 Ranger Lariet
OK here is my experience with the Map update:
I tried the download and and it ABSOLUTELY sucked. Would not load, I had this same problem with the 1 18 update so as I did with the 1 18 update I coughed up the $40 for SYNC's USB.
It tried to load, actually it seemed to load but at the end I showed MAP 1 18.
So after several hours over the course of two days being bounced around from one 800 number to another, I finally got someone who actually listened to me after realizing I was actually tech savvy. I noted that the directions to the SYNC USB mentioned SYNC 3.4 and how just a week prior I had checked the FordOwners.Com website and it was still not available. She checked and SURPRISE! 3.4 is available.
I thought "great" I'll be forking out for another company USB BUT I would give their download a chance.
It freeking worked! I finally had SYNC 3.4 on board!
I forgot to mention that the "Nice Lady", the truly helpful one insisted that according to their records, I had MAP 1 19 loaded, this was before my SYNC 3.4 update BUT I showed 1 18 on MY screen.
So I reloaded the MAP update and sure enough (after a 30 minute load) I now have MAP 1 19.
Let me add that after I loaded MAP 1 19 with SYNC 3.3 I lost all NAV Voice Commands But I have everything in NAV working now.
I also had to do a Master Reset and reload Ford Pass to get everything to work.
