Fox/Ford Performance 2.0 leveling kit help....
KevinG
kevin
nevada
2020 Ranger XLT
Business owner
I know the spring rates from Fox direct and Fox/Ford kits are different. I bought the Fox/Ford 2.0 leveling kit and was wondering what the actual pre-set height was. So I called both Fox and Ford Performance with zero help or answers so here I am, hoping someone has experience and might be able to answer and some pics of theirs. Also, if I were to adjust my coilovers, Fox has made it very difficult to do so. I find it hard to believe both companies are unable to answer a question about a $1500.00 kit they developed :angry:
KevinG
KevinG
kevin
nevada
2020 Ranger XLT
Business owner
Perfect, thanks for the reply. I will just bolt it on and go. Any pics of your truck?
KevinG
KevinG
kevin
nevada
2020 Ranger XLT
Business owner
Looks great and thanks for taking the time to post. :fistbump:
TAHITIANRANGER
steven
tahiti
2020 ford ranger asian model XLT
store owner manager
Pics of Ford/Fox 2.0 kit (only front shown)
really nice, I will mount my fox supension kit next week, how do they perform ??? on and off road ??? did you see a huge difference with the factory suspension ??? tks
krisrayner
Kris
‘20 Ranger FX2
See my recent post on Fox 2.0 - How much did it lift. On my 2wd it was basically too much and would top out harshly. That was with the collars at 48mm from the bottom of the threads. I lowered them to 35mm it has made a difference in ride quality and stopped the harsh top out. Also, that was on the Ford Performance Fox kit.
Pinepig
Charlie
Sacramento
Last count was 12
lol
Only added the Ford/Fox 2.0 Leveling Kit. Everything else is stock.
They appear to be black crinkle powder coat on them, every other picture I've seen here that are just aluminum color like mine.
Metalshift
Vancouver Island, BC
2019 XLT
Those are definetly cast steel and hollow. Look closely at the pictures. You can see the rust. I wonder why Ford changed the material. I wonder what else has changed.
burchs
Stephen
Louisville, KY
2020 Ranger XLT 4x4
Hey can someone verify that I'm looking at an aluminum knuckle/spindle? Obviously a newbie to working on my own stuff and want to make sure before I try to fit some new UCA's on.
Thanks!
Thanks!
Yes it looks like an aluminum one. They went over to the cast steel ones late 2020. My build is 11/20 and I have steel. What year/build is yours? That’s how you can tell for sure
burchs
Stephen
Louisville, KY
2020 Ranger XLT 4x4
Thanks, finally went and found the build date of 03/20. Reading all the posts it seemed a lot of the 20's were steel so I started trying to figure it out, I guess I was early enough to get the Aluminum, which is good since I didn't see the note about the change in spindles until after I ordered the Fox stage 2 kit :facepalm:
Pretty sure the change over happened mid year 2020. You lucked out!
I can change over my steel for aluminum ones for $250 for the pair but I better have new UCA if I do decide to go that route later myself.
