I wished I would have used a sawsall and made quick work of the stock bars in hindsight.No need to remove the front bumper to install. I used the BDS on my Ranger and the Fabtech on my step dads Ranger and zero issues with sliding these in. Now to get the old bars out I used a sawsall on mine and I must have went through 3 blades per bar. Next go round when I did my step dads I used a cut wheel like BUUUUUTTTTTAAA.Well you have to take of the front bumper to install the fronts. That's the easy part. That only took about 45 minutes to an hour. To get the bars installed and the bumper remounted. The back bars you need to remove the foam material under the back of the wheel well. That was brutal. Crawl under there and eye it up. You'll see what I'm talking about.
I dug into this a while back... here is what I wrote on a previous thread.Looking at the fabtech offset intrusion beams. Anyone know how well the retain the safety standards as the originals? It says on the site that they are 1/4" thick. Anyone know how thick the factory ones are?
how did it Go?Doing my truck this weekend the all makes sense to me
Sorry never got to it I have my friend who is a ford master tech installing them this Friday for me.how did it Go?
Their advertising states "Retain the safety and security benefits of occupant protection." Ask them to send you some sort of certification documents that provide evidence that their anti-intrusion beams are stronger or even the same as stock.I installed the ready lift anti-intrusion beams. They are impressively beefy, and add some needed clearance. I currently have a 275/55/20 tire (2" level), and with the wheel locked both directions there is still plenty of room. My rim is 9.5" wide 12mm offset. I would think I could fit a 33"x11.5" tire, based on the additional room available.
