Dead Battery
Osbornebad
Bill
2019 Ford Ranger XLT 4X4
Yesterday I pushed my fob as normal to start the vehicle and there was no response I attempted this twice as I got closer to the vehicle I could hear no response from the vehicle I used the key to enter the vehicle I inserted the key into the ignition and nothing happened it appeared to have a dead battery I popped the hood checked the battery post terminals to make sure the connections were tight and no response from the vehicle no power it was cold so I jumped into the vehicle I sat there for 20 minutes while waiting for someone to come give me a jump and when I exited the vehicle the alarm went off I thought that was rather unusual since the battery was dead I turned off the alarm with the fob close the hood push the fob in the vehicle started has anyone else experienced this problem with a 2019 Ford Ranger the vehicle since has been operating as it should.
On the drive home I did stop by and have a auto technician at a shop put a battery tester on the vehicle he did say the battery was in good condition and the alternator was charging as it should.
BGDOGY
Tommy
virginia
2019 Ford Ranger Lariat 4x4 crew cab
Had a similar experience once. Came out from the store and nothing. Open and closed the door, then sat in the truck for about 10 minutes then it started right up. There have been other people here with the same Gremlin happening to them. It hasn't happened to me again in two years. Hopefully that will be your case too.
I had a momentary no power situation, but it resolved after about a minute.
Went to unlock the truck, no love. Used the key.
Got in and put the key in the ignition to start, no love. No lights, no screen images, nada.
Tried to unlock with the electric door switch to unlock the tailgate to load groceries. Nada. Dead as dead can be.
Got out, closed the door, went to the tailgate and realized that I don't have a key lock back there.
Went back to the driver seat, put the key in again and the screen lit up and it started.
I have no idea why it did this. Maybe a computer reboot?
It's never happened since and, even though I have a battery jumper, I don't think it would have fired up.
Did you keep trying while you waited that 20 minutes? Was it just as dead as your first try?
Did you have to jump it or did it start after the alarm went off? If the latter, then it was some computer error and not the battery.
Let us know what you find out.
HenryMac
Mech. Engineer - Retired
CAB
Charles
Celina, Texas
2022 XLT Tremor 301A; 2021 Lincoln Nautilus
Insurance Adjuster
Happened to me within 45 days of new. No response at all. Had remove and reinstall battery cables and it started immediately. Has not occurred again.
I’m starting to wonder if this is caused by SYNC updates and when it decides to write. We’re any or all of you on automatic updates?
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
https://www.ranger5g.com/forum/threads/truck-wouldn’t-start.9677/#post-179027
Based on others having this same thing happen ^^^^ I carry a 10 mm wrench in my console.
If this happens, pop the hood, take the wrench and unhook the negative battery cable. Wait a couple minutes then hook it back up.
It's like rebooting your laptop computer when it does stupid shit... so to say.
Same here. Came to my truck once, completely dead. Check battery voltage and it was perfect. Disconnected the negative for 2 minutes, reconnected and she came back to life. Ever since then I carry a 10mm in my truck.
Jason B
2021 XL STX SE 4x2
machinist
probably not a SYNC issue, as that is mostly just infotainment. It sounds more like something with the PATS not recognizing the keys and disabling the system to avoid theft.
This is one of the Ranger - quirks that had me scratching my head. No start issue then magically starts.
After digging into the wiring diagrams - and knowing one of the quirks of relays (they sometimes stick)
I have what I believe is the culprit and that is a sticking PCM Power Relay
With sticking relays (after residual voltage) drops the relay will relax back to normal position.
This is the 10-20 minute time period that owners are describing.
So if this happens - and I am correct - try tapping and or removing and reinstalling the PCM power relay in the engine compartment relay center.
Another relay of possibly is the Run/Start relay in the same relay center.
But if you have no start from both - remote start and ignition switch - it’s going to be the PCM Power Relay
I don’t think it’s a Sync or TCU issue- as that would not account for the 10 to 20 minute time out period.
Tremor-R
Scott
Belton, TX
Agriculture Chemical Formulation
Just had the same thing happen to my 2023 Tremor.... and this was the 2nd time. First time happened in early 2025. Had to enter the truck using the door key/lock. Put the key in the ignition, and everything was dead.... as if the battery had been disconnected. About 5 minutes later, everything came back to life and the truck started/ran just fine.
Today (Fri, June 26, 2026), it happened again. Battery BTW was replaced about 10 months ago with a new Ford OEM unit. Same routine.... unlock the truck with the key, get in, put key in ignition, and nothing... dead as a door nail. I then opened the Ford app on my phone and hit the unlock button. About 3 seconds later, the truck came to life, started, and appears to be running fine. Good thing I wasn't in a hurry, like trying to run from an oncoming tsunami, I would've been fish food, lol!
Anyway, with only 65k miles, putting itself into 4-low while exiting the freeway (related to main fuse box), 3 10R80 tranissions (yes, on my third tranny), 1 AC compressor, 1 main fusebox and wiring harness, 1 main battery, and 1 wheel speed sensor later, I can honestly say that I'm NOT surprised..... wife thinks I'm driving Ford's version of Stephen Kings Christine.
SigOris
Greenwood Maine
Retired DoD EE
And if you trade it for another Ranger they’ll low ball you because of the service history. 😤😠😡
Tremor-R
Scott
Belton, TX
Yes, I contemplated that or selling it. Crazy thing is, I wouldn't want to pass those, and any future problems, onto someone else.... just wouldn't be fair to them. At this point, I'm going to just pay the darn thing off, and if any other issues present themselves, I'm going to stuff a Coyote in it and turn it into a short course truck. Lucky for me, I was able to get my wife a ride in a Rally Fighter and she had a blast. As a reult, I'll have her approval to build whatever I want, as long as it goes fast in the dirt..... I'll take a lemon, so to speak, and make some lemonade.
