Dead after. Period of non-operation
WheelMon
Otto
Vallejo, CA
autio.com
@Autio Travel App by Kevin Costner
I had shoulder surgery on May 1st and had not driven my 2019 ranger since.
Got in today and it was completely dead.
Is there a system shut off / shutdown that kicked in after a period of non-op or likely the battery drained?
Any info greatly appreciated.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Has happened to many of us on here, including me. Disconnect negative battery terminal for 2 min and reconnect. After this happened to me, I now carry a 10mm wrench in my door cubby. Some say this happens when the truck updates itself. I don't know what caused it in mine as I use my truck everyday.
RD_Kona
Steven
Denver
2023 Ranger XLT Tremor
My wife and I were recently on a 14-day trip. Both my Ranger and her Bronco Sport started up with no issue.
We keep the vehicles locked in the garage and keep the keys in the kitchen so the vehicle is not reading the key as nearby and getting ready to start (a recommendation from a different vehicle forum).
Maybe deep sleep mode occurs when the vehicle receives the signal from the key fob as being nearby.
This is possibly a case of the mysterious scenario where the truck will not start then after a 10-minute wait period or so, it magically starts without a jump start or battery charge.
Instead of battery disconnect, try pulling and reseating the PCM Power Relay, in the BJB under the hood.
I am trying to determine the root cause of this little quirk and am leaning towards that relay is the issue. (Stuck)
If you disconnect the battery, you are doing the same thing, but pulling the relay is quicker and requires no tool.
This is just a guess here and trying to find the exact root cause, and the PCM Power Relay is the most logical part of the system that would not allow the truck to start and then magically start 10 minutes later.
I know that most likely it will just need a jump start due to the time frame it has been sitting, the main thing would what the battery voltage is, if decent voltage of 11.0 volts or so then you should get something out of it, dash lights, chimes etc.
Rp930
Denver
After a month of no operation I would expect a dead battery.
Jason B
2021 XL STX SE 4x2
machinist
$10 says that 10mm will have disappeared when you need it.
Bud
Bud
Rio Vista, CA
2019 Ranger XL supper cab 2019 Volt 99 XK8 Jaguar
Sailor
When I don't use my truck for a while I get a message that says something like "system shut off to preserve battery" The battery is almost 4 years old.
1pt21gw
West Coast
Ye' Ole Traveler
My battery is currently measuring 3.85 volts. No lights, chimes, or nothing and just drove it last week.
Waiting for my battery booster jump starter to charge. If I'm not able to jump start it, its call the Ford Roadside to have her towed!
WheelMon
WheelMon
Otto
Vallejo, CA
autio.com
