Biggest tires, no lift?
Marshal.
Marshal
Canada
2019 ford ranger, 1979 Mazda rx7
If you’re willing to upgrade to a 17”, my calculations show a 255/70r17 is .5” larger diameter than the factory size. It’s what I’m going to spec out to replace my 18” wheel/tire package as I’m going to a 17” wheel now
Just an update; this is what 255/70r17 looks like. Zero lift, zero rubbing under any conditions. 1” bigger than stock. Wheels are 17x7.5 et35
BDoc
Bryan
WA
2019 Ranger Lariat FX4 SCrew
The new setup looks great!
285/70-17, no lift yet thanks to Eibach dropping the ball:headbang: But with the front/rear beams removed, everything clears. Slight rub on rear liner at extreme lock but not an issue. Liner shows no wears after thousands of miles. Caveat...I have +20 offset and you will need the same if you want the same result :)
BDoc
Bryan
WA
Like this more every time I see it, Sid. Got a great stance too.
Thanks but would be perfect with the front lifted lol:)
Stic-o
Stic-o
Lake View Terrace, CA
How's the mileage difference? 1-2 less?
Hounddog409
Tod
Ohio
F150
What tires are those? Falken?
And please report mpg change when you get some miles on em.
Looks great btw.
I really haven't nailed that down yet...I'm getting 23+ on highway, 18-19 city. That said, could be that's a pesimistic calculation due to it being calibrated for smaller 265 OEM tires. 285 travel further so logically, I should account for the difference and the real mileage should be slightly higher...does that make sense or am I getting that backwards?
doug910
Detroit, MI
'19 Ranger, '02 BMW 540i
I'm wondering the same, I went up an inch as well with the Falkens. For one revolution of the driveshaft, the tire now covers more distance so yes, the MPG should be inflated. But, that also assumes that you're using the same amount of fuel for one revolution of the driveshaft. Now that the tires are heavier with more load on the engine, you should be using more fuel per revolution of the driveshaft which deflates the MPG. I think it kinda balances itself out?
doug910
Detroit, MI
Another confirmation on fitment with 265/70/17 (just under 32") whereas OEM is 265/65/17 (30.6"). I went with Falken Wildpeak AT3W - with a set being $500, can't beat the value. There's no rubbing at full lock when static, but I will note that when I zipped into a parking space, I heard a little bit of rubbing when the suspension compressed a little bit. Not too worried but I wouldn't go bigger without a lift.
I'm also surprised at how much of a difference I felt on the road. Truck feels a little more sluggish with the heavier tires and I feel the extra inch of ride height when driving too. I also just went to the off road park a few weeks ago with the OEM Hankook's, and I'll be going again this weekend with the Falken's, so I'll update with a comparison!
doug910
Detroit, MI
Update: sorry guys don't mean to spam the thread, but here's a side by side pic that I just got between a stock FX4 XLT Ranger and my FX4 XLT Ranger with the 31.6" Falkens. The size difference is so evident side by side!
BDoc
Bryan
WA
That's a great comparison photo. Gives a better idea of the difference and just how much the new tires fill in the wheel well.
toddiscdn
Todd
Blue Point, Ontario, Canada
2019 Ranger Lariat 4X4
Keep us in the loop, these are the tires Im looking at to replace the stockers in the fall before the snow files, be interested in how you like them, noise level etc.
