Beware of Air Fresheners
MechanicalBob
Nevada
2022 Tremor
I went through a WOW carwash about a month or two ago and got an air freshener as part of the wash. I removed it from the package and slung it over the gear shift lever because I don't like things dangling from the mirror. Yesterday I went to throw out the air freshener because it was pretty well used up, and it was stuck to the trim in front of the gear shifter. At first I thought there must have been something sticky on the air freshener, as it looked like gum stuck to both my truck's plastic and the air freshener. I tried rubbing it off but wasn't getting anywhere. Turns out those things are VERY hard on some plastics when in direct contact. Now I've got a ruined piece of trim that is pretty easy to see.
Moral of the story: read the warnings on EVERYTHING. I didn't even think air fresheners had warnings, other than maybe "don't eat". If you're going to use one of the hangy-type air fresheners, either hang it from the mirror or put it on the floorboard or under the seat.
On a related note, if anyone knows of a source for a wrap or something like that to cover the plastic from the cupholders forward, I'd appreciate it!
You could try some 303 Aerospace protectant on the area. First try some Isopropyl alcohol to loosen up the stickiness. Then take the Aerospace protectant and spray some on, let it sit for 5-10 minutes and see if it starts to dissolves the stickiness. This is also one of the best UV protectants for your interior (and exterior) plastic and leather seats.
https://www.amazon.com/303-Dust-Lint-Staining-Repellant/dp/B00JG3OIFU/ref=sr_1_4_sspa?crid=3GIPHFYRECJDT&dib=eyJ2IjoiMSJ9.BPI4zHWcsETnCuzqELbJOAe-gfUTN3FeKSYoc4-_0Nv_vgLrXnwty_cF4Im0Cau8KVDJw0HTko9Fn00U0FS1bmAATTv7KnJQKV583sdT9FmynoWGrTH0_nWZytZ0CjiZjCYj4bDQKtB_gjVrPz-3is2LllfVvJ8oOsqsSY2Akn3eWd8Z5b1HCBlrtqHK9Sucz7FTWbakdIfCcSJOrpMkod7wsS2_n3Pcq6Rf8ROl0rGYrsVjj2YfvPqY7BkXNsD0tWhH41VbHNYL1-Pq9d3xnbiYDUFWeEGQ1MNzDUZ9PDc.CIS7dC77k4Adnulgwp8DJtTlUVpZB0a3Xe9y7prhC6I&dib_tag=se&keywords=303+aerospace+protectant&qid=1737997407&sprefix=303+,aps,163&sr=8-4-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
  • ULTIMATE PROTECTION: Shield your outdoor products from harmful UV rays, dust, dirt, salt water, & staining with this 303 protectant. Prevents fading & cracking for long-term care.
  • NON-GREASY: This 303 protectant also offers a non-greasy formula that dries to a smooth matte finish for a like-new appearance for both the exterior & interior.
  • VERSATILE: Effectively rejuvenates a wide range of surfaces, including vinyl, plastic, synthetic and natural rubber, PVC, metal, gel coat, fiberglass, and stainless steel.
Try farting in your Ranger....it's natural, and doesn't leave any sticky residue !!! ?
Also keeps rodents and unwonted passengers away.
I’ve tried it - several times - doesn’t work.
It will probably work for @Doc .
WOADKIL
Wil
Cyber Orange County, CA
RETIRED ENGINEER
I can smell it from here!!!!!
veedubtuner
Morgan
Tulsa, OK
VW Parts
Unless you shart by accident ?
"Here I sit
All broken hearted.
Tried to sh*t
but only farted.
Then one day
I took a chance
Tried to fart
and sh*t my pants"
I do not think 303 or Goo Gone is going to help for this - as the plastic is melted and deformed from the chemical reaction from the air freshener (oils) touching the plastic.
Same reaction as the worm lures and attractant sprays in your tackle box trays if you let them sit for extended periods.
I would suggest Ebay for a replacement trim piece.
Dereku
Chicagoland Area
I have a spot in that very front tray by the shifter. Same thing.
I keep stuff in the tray. Try not to look at it.
