Battery Replacement
Muscleford
George
Ohio north coast
Retired CFO
It appears that it may be time to replace my battery. My truck is a '21 with the original battery. I got a message on the screen yesterday but I caught it out of the corner of my eye while starting the truck. It was something about starting the truck to......something about the battery. It went away as soon as the truck was started.
I understand that Motorcraft batteries are not the best quality. So, would the average employee at O'Reilly or Autozone be capable of replacing it without issue?
I also believe two different physical size batteries were used in Rangers, how to tell which size you have?
What has to be done when replacing it? Any resets that need done? I do not have Forscan.
Thanks.
George
RangerBill
Thanks.
George
My 2019 still has the original Motorcraft battery (7 years). You should reset the BMS (battery monitoring system). Use the following procedure:
Ranger Reset Battery Monitoring System (BMS) After Replacing the Battery​
To reset the BMS on a 2019+ Ranger turn the Key On then operate the high beams 5 times, then press the Brake pedal 3 times and confirm BMS reset by flashing battery light on the dash.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Also the manual states, windows up and doors locked for 24 hours. That’s the only way that mine would do the light flash brake pedal thing.
Muscleford
George
Ohio north coast
Retired CFO
So if for instance, I have o'reilley do it, can I drive it home then do the windows up /doors locked thingy?
RangerBill
Thanks.
George
The size will be on a label on the battery. If you install a different size battery, you will need Forscan to change the battery size in The BCM. If you stick with the same size and type battery, you won't need Forscan. I have not heard of having to have the windows up and doors locked to do the procedure I posted above. I don't believe that it is necessary.
PINKS
Perry
Canada
2021 Ford Ranger Tremor
Forestry Tech
I just replaced the battery in the wife's 2021 Tremor last year, I just went to the local parts store bought a regular 12v lead acid brought it home pulled the original out...put the new one in and been driving it with no issue...no resets of any sort, no codes of any sort!😎👍
RangerBill
Without resetting the BMS or changing the battery type in the BCM, may cause issues later on.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Yes.
Mine suddenly went dead in the summer two years ago. Went down to the garage to go to work, turned the key, and got nothing but a click.
Called AAA to jump it and drove across town to Auto Zone and got a Duralast Platinum.
Batteries these days are on borrowed time after three years.
dtech
colorado
You have to manage the battery , the BMS is incapable and left unaltered will result in shortened battery life, it's programmed chasing minute gains in mpg as opposed to maintaining a healthy battery.
For
The label point matters here, especially for the wife's Tremor example — going from an H6 to an H7 physically fits but the BCM still assumes the old capacity, so charging strategy can be off even with no immediate codes. I'm weighing whether to drop in the same group size on my 2020 XLT or step up while I have the tray out. What I can't decide is whether the BMS reset alone covers a size change or Forscan is genuinely required, since opinions differ. Looking at Best Group 24 Battery of 2026 for sizing reference while I sort that out. Anyone here actually done a size change and reset only the BMS?
For me since I have the scan tools to do it:
Its much easier to do the reset with the tool, mainly for a confirmed (Feedback) Reset successful
Ref: Battery Size (Upgrade) all the BMS Reset will do is reset (Programed) data withing the system, mainly it resets the (Time Since Installed) date and refreshes learned data (SOC/ SOH)
It does not know (a larger battery) has been installed and will continue to charge the battery as if its the OE size.
When you change the (Battery Size) with Forscan - it adjusts the charging rate for the bigger sized battery and as well (It will automatically) change the (Time Since Installed) date.
The main thing (component) in the system is the (BMS Sensor) and its SOC Drift over time and the programmed algorithm for charging as the battery ages.
We have dove deep into the system in 2 threads;
The Max Battery Life - kind of picked up where my initial thread dropped off and has some real world data monitoring
At about page 52 - we started detailed monitoring with live data (Max Thread) to actually see what is happening behind the scenes
Charging Sys-Full Description-Trigger Voltages-Test Results | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Maximizing Battery Life | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
RangerBill
A BMS reset will not change the battery size or type. It must be done with a program such as Forscan so the BCM charges the new battery properly.
harringtondav
East Central Iowa
Not much to add to the thread, just my experience.
I replaced my 2019 battery w/in the last year. I couldn't cross the OEM group size so I Googled it and came up with group 48/H6 and group 94R/H7. AGM battery.
I bought the 94R/H7 and it was a bit too big. Apparently its for higher trim models with more electrical demands.
It fit the battery tray, but the already tight cables and wires were a very tight stretch. I had to cobble the battery blanket to fit.
Point is unless you have a high trim Lariat with lots of extra electronics, get a group 48/H6 AGM.
dozxab
Prescott AZ
I ordered a bigger cover for mine when the truck was 3 years old, planning to go to the bigger battery. I did use Forscan to change the battery size. Under $200 at Costco. I did try the lights and brakes method to see if it worked. No issues. A minute with a tape measure will tell you which you have.
H6 70 ah
Length 11
Width 6 15/16
Height 7 1/2
H7 80 ah
Length 12 7/16
Width 6 15/16
Height 7 1/2
harringtondav
East Central Iowa
Good to know. What is the p/n for the larger battery cover?
I used a USB to OBD power supply when I replaced my battery. It seemed to work as intended. I haven't updated my BMS for the extra 10 amp hours.
