Battery Replacement
Muscleford
George
Ohio north coast
Retired CFO
It appears that it may be time to replace my battery. My truck is a '21 with the original battery. I got a message on the screen yesterday but I caught it out of the corner of my eye while starting the truck. It was something about starting the truck to......something about the battery. It went away as soon as the truck was started.
I understand that Motorcraft batteries are not the best quality. So, would the average employee at O'Reilly or Autozone be capable of replacing it without issue?
I also believe two different physical size batteries were used in Rangers, how to tell which size you have?
What has to be done when replacing it? Any resets that need done? I do not have Forscan.
Thanks.
George
RangerBill
PA
Thanks.
George
My 2019 still has the original Motorcraft battery (7 years). You should reset the BMS (battery monitoring system). Use the following procedure:
Ranger Reset Battery Monitoring System (BMS) After Replacing the Battery​
To reset the BMS on a 2019+ Ranger turn the Key On then operate the high beams 5 times, then press the Brake pedal 3 times and confirm BMS reset by flashing battery light on the dash.
