Anybody planning to lower their 2019 Ranger?
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Any way to do a 2" rear drop?
No, I made a thread about this and people freaked out. No way to do a mild drop on the rear. If you want to be brave and mess with the leaf springs.... good chance they will snap on you.
I will likely bring the nose up just a bit.. don't want to as it's perfect at the current height in front... with bilstein struts then run a bit larger tire to level it and fill in the gaps a bit more.
RangerDangerStranger
SF Bay Area
2022 Nissan Frontier SV in Tactical Green Metallic
Cool Dude
I was thinking of getting a custom set of leafs, with 2" of lift, combined with the 4" drop, that would do it. but now I hear the drops 6", so why not a 4" lift in the spring, combined with the flip kit, ought to be about right. i'm 6', and u can barely reach over into the bed. do not like this.
Rinn69
N. Central Iowa
Retired USAF MSgt
If my brain is working correct...fingers crossed:
Using only a flip kit, gets you ~6" of drop if you bolt the springs to the factory locations....
Using a flip kit with 2" lift springs gets you a ~4" drop if you bolt the springs to the factory locations...
Using a flip kit with 3" lift springs gets you a ~3" drop if you bolt the springs to the factory locations...
Using a flip kit with 4" lift springs gets you a ~2" drop if you bolt the springs to the factory locations...
Is my "math" correct ??? Anyone ??
SF Bay Area
Cool Dude
Yep. Can i get some of those springs, Please?
SF Bay Area
Cool Dude
What did they charge you for the install. allot of welding.
