98k and cracked gasket, told I need new engine
Stevedbvik1
2022 Ranger Tremor XLT
This is the same thing that happened to me '20 at 36,400 miles. I dumped the rig, and lost all faith in Ford. These failures are happening way too often to be considered normal. Even with the small sample size that is this forum, too many people are having problems.
Cracked cylinder wall?
MarioCart
Mario
Canada
Ranger
Employed
Havent read all the posts yet, but you kept getting lights and warnings and just added coolant and kept going??
Might have some follow up questions as I read more
MarioCart
Mario
Canada
Ranger
Employed
My thoughts on the engine being a turd.
All it takes is one, and everyone panics regardless of how many people are in the pool and not dropping doodies.
dtech
colorado
isn't that what Captain Kirk did on numerous Star Trek episodes, despite Scotty warning she was about to blow ? Sounds like bad advice may have been given by the dealer and ended up with a blown head gasket and possibly a cracked cylinder head - symptoms of overheating likely due to low coolant.
Swishpapasweets
IL
2019 Ford Ranger XLT,1990 Ford Bronco EB,2024 Nissan Frontier Pro4x
IDK bout all that man, the bronco doesn't have the same transmission as us, and just cause we share the same chassis doesn't mean everything else will fit. I would love to see it but tbh its gonna be a bitch to do, even on a bronco
There's a place out in Ohio that has turn key used engines for older vehicle projects that I would get an engine and transmission for.
Swishpapasweets
IL
Be careful when you say the same chassis. The Bonco chassis is different from the 5G chassis. Suddle changes were made to get the V6 to fit. That is one of the reasons the 6G is wider to fit the V6 in. You will need a big shoehorn to get that 2.7TT into a 5G Ranger with all the associated plumbing. Not saying it can't be done, just good luck. It will not be a drop in.
That's fair but shouldn't be too crazy to try but it's not on my list to do for the foreseeable future as I need to finish other projects.
so what dealer have you been going to? Have you checked the oil to see how it looks? have you checked the coolant to see how it looks? I do not trust any ford dealer so far. id want someone not dealer connected to give it a look
Conman50
Conrad
2019 Ford Ranger; 2014 Ford Fusion
Could your issue be related to this?
Where there is a small slit milled in between cylinder walls and it makes a weak spot?
I thought Ford revised the block after 2019.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Our 2.3's shouldn't have this problem.
OP, I'd be looking for a second opinion.
'Ford doesn't recommend replacing the head gasket'
Uhh, they did that to piles of Focus' when those were eating gaskets.
You need a good non-Ford dealer shop since you're no longer in warranty.
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
Sounds like you drive a lot. To me, with the kind of miles you put on a truck and given your self confessed total lack of knowledge of all things mechanical, you really need to find a skilled shop you trust and start writing checks.
Given you didn’t mention any puddles of coolant on the garage floor, if you have been adding coolant for 20K miles, you very likely are looking at major mechanical work.
If you were my cousin, I would tell you to find another shop with a great reputation and get a second opinion. If the opinions of both shops match, pick one and bite the bullet.
Squatchranger
Orlando
19 ranger lariat
I wish you the best of luck but that is going to be a huge undertaking. I hope you succeed and it isn't too expensive or difficult/problematic cause that would be awesome.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
As for a 2.7 swap, it'll be some work. But people were shoe horning V8's in the 4G Rangers.
Could the EGR problem be because coolant is going out of the exhaust?
EJH
Ed
Subarus, 2021 Ranger
worst part of owning a ford is ford dealers.
This Ranger is my first Ford and I agree :(
For the most part, I don't actually think it is the dealers, but rather what Ford corporate will pay the dealers.
My family has (or had) 4 Subarus over the last 15 years. The dealer experience with Subaru is 180' from Ford. Subaru will troubleshoot and fix just about anything that can be remotely related to warranty.
