ControlNode
- First Name
- John
- Joined
- Nov 29, 2021
- Threads
- 17
- Messages
- 1,734
- Reaction score
- 3,755
- Location
- Eastern NC
- Vehicle(s)
- 84 Civic "2000S"/16 Focus RS/21 Ranger XLT
- Occupation
- Computers
Yes, most AWD vehicles have 3 diffs (center, front, rear), the center is the one that allows different front/rear diff carrier speeds. The Focus RS is one of the exceptions.This is a good explanation - one that I have been looking for - thanks. So for an AWD (e.g. Subaru), all the wheels have power, but there’s a diff or 2 to allow the axles to turn at different speeds?
Most 4WD just have 2 diffs (front and rear) and when connected in 4H or 4L modes the diff carriers are locked into a 1:1 rotation rate.
And then there is the Focus RS, an AWD car with only 1 diff in the front. The front diff carrier is direct connected to the drive/prop shaft through normal ring/pinion gears and drives a spool in the back at a fixed ratio, it is not 1:1 as the rear is geared to turn a little faster. Then there are electronic/hydro controlled clutch packs on the left and right side of that spool that engages to send a varied about of torque to its connected wheel. Normal use just cruising along the car is 100:0, but can got 30:70, and of that 70% going to the rear 100% can go to a single wheel back there. This car is more planted on snow/ice than my wife's Jeep in 4H. To help with traction is also uses the front brake system to create an e-lsd by clamping down on a slipping wheel so all the power is not wasted there if the other front tire as more grip.Things to understand to really know the "why"...
-4wd/4x4 vs AWD
-transfer case (vs clutch packs vs viscous couplings, etc)
-differentials (locked vs open vs limited slip)
