275/70/17 on Stock Sport Wheels
BButah
Bryan
Draper, UT
I've posted info on some other threads; but in the spirit of trying to help Fellow-Ranger-Owners decide on tire size for the Stock Sport Wheels, here's my set-up:
BFG K02's LT275/70R17
ReadyLift 3" Level (front only)
Stock Crash Bars Intact
After the initial install, I decided I wanted a bit more "aggressive" stance, so I added the 1" BORA spacers. (FWIW.... the above pic's are with the spacers installed)
Here's the spacer's post:
https://www.ranger5g.com/forum/threads/wheel-spacers-on-stock-rims.6624/post-130802
Hope this helps!
Cheers!
NvrFinished
Shea
SoCal
2020 XLT 4x4 Rapid Red
Hope this helps!
Cheers!
Looks great! How does it ride? I'm curious since that size is a load range E. I was considering that size or the LT255/75R17 BFG K02. It's only slightly taller, but 1/2" narrower and a load range C.
BButah
Bryan
Draper, UT
Thanks Shea!
I remember your excellent/informative comments on the tire pressure thread of this size tire when I "chalked" my tires:
https://www.ranger5g.com/forum/threads/bfg-ko2-lt275-70r17-tire-pressure-info.7792/
I really like the ride, and while I only had the original tires on for a short time, I don't think there was/is much difference?
I am very happy with the on-pavement performance & overall feel/ride; and with the occasional off-road/snow use I have encountered.... for me, the tires are excellent!
I'm no expert; but my wife is and she says "I like how your truck rides.... it's comfortable and smooth".
So I've got that going for me!
:cool:
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Emissions testing supplier
Edit: NM
NvrFinished
Shea
SoCal
Thanks Shea!
:cool:
Thanks much! I've been looking at other brands, but the BFG K02 has proven over the years to be a solid go-to tire.
You can get the 275/70R17 in load C also.
In other brands you can get a load range C, but I've decided that I'm going to go with BFG at this point.
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Edit: my bad, was looking at the wrong size.
ranvac11
Enrico
philippines
ford ranger 4x2 xlt
businessman
guys has anyone tried these 275/70r17 by cooper AT3 LT if it fits without lifting?
Shadowdraxx
Ric
TX
2020 Ranger XLT Sport
Bum
Depends on if you have crash bars on ur Ranger in the US no chance
Your ROW Ranger might be different but here’s what I learned on my Canada/USA Ranger...
When I was installing my Rough Country 2-1/2” level kit, as an experiment, I mounted my 275/70R17 General Grabber A/T 3s (32.2”) in the front before installing the kit because I knew people would ask this question.
They rub - everywhere - period.
I doubt they would even clear the knuckle with stock wheels - my after market wheels have a +15mm offset, so they cleared.
Even with my 2-1/2” level, they are very close to rubbing the crash bars. Looking at how they fit my Ranger, I’d say 275/70R17s are a bit better suited to a 3” lift, barely clear the crash bars on a 2-1/2”, will likely rub on a 2”, and are a definite “no” on zero lift/level.
Fawnbuster
Indiana
Retired 34 years as LEO
I think they will help you achieve a smoother ride, although someone could make an argument against.
I guess the question would be “to what degree.....” very subjective.
Help me understand how aftermarket UCA's would help the ride? I've never swapped or replaced a set so I'm clueless on these. Do they change they ride height and or wheel angle as well?
tebower
Ted
2020 Ranger XLT
IT Support
I just put some 275/70/17 Cooper Discoverer AT3 on my generally stock XLT Sport. I love the look, ride is fantastic. I have a RC 2.5 leveling kit on. That's the only mod.
jleds
Jay
Honolulu
2019 Ford Ranger XLT
Nice set up man! What running board to you have installed?
waloud
Whitaker
Louisville
2019 LB Ranger
Do they rub?
