2 annoying things i noticed after 1st week with new Ranger
Thanks Dave,
The guy in the video was iffy about exactly what all it affected other than the A/S/S. I am assuming that it is wired exclusively to only the A/S/S module? When I messaged you about the LED light fix, I was under the impression that every Ranger was equipped with at least one AC outlet but looked before buying the light and discovered I don't have one. Didn't come with my package.
I haven't pulled the wire because I've been just using the LED light and it's worked out good. I haven't seen anyone say that pulling it affected anything else on here or in the comments in the video. I would think it would throw a code or some warning on the dash if it were connected to anything else. IIRC the 110v outlet is added as part of the 502A package?
CB750F
Qc
Human
I like the automatic start stop.
OrangeStreak
New Mexico
2020FRL
Alan
Grand Junction, Colorado
2020 Ford Ranger Lariat, 2014 Harley Tri Glide
You Too???
Kataphrakt
Tim
Grand Rapids Michigan
Ranger XLT FX4 Offroad
Mechanical Engineer - Mirrors
2. Hybrid electric seat, where some of it is manual and some electric. Why not make it all electric in Lariat?
I spoke with some guys from the seating division of my sub-group, and they spoke how one of the biggest challenges they encounter is fitting the huge motors required under the seat for 3-axis power adjustments.
I wonder if the AUS/EU vehicles had fully-powered seats, and if so, wonder if US specs require more output torque on the motors
jzinckgra
Maine
2020 Ranger Lariat
That seems odd. My Ridgeline had them, my wife's CX5 has them, the F150 has them I think. Lots of vehicles have them. It's not like the Ranger seats are too small to fit them underneath right? You work at Ford? Thanks.
VAMike
2019 Ranger Lariat SuperCab
Australian top trim and lariat both described as "8 way power driver seat". I'd guess they didn't care about power recline in Australia and Ford just cheaped out and didn't redesign the seat for the US market.
Kataphrakt
Tim
Makes sense, they'll switch the frame to fully-boxed, but wont update any of the "must-have" amenities.
I dont know how much space/how easy it would be to fit the motors under the ranger's seat since i have no desire to take mine apart, but as is pointed out above, the seat was likely carried over from the AUS version, which did not have power recline. Dont work at Ford, just a Tier-1 auto supplier. Brought up the issue since thats what i had talked with some of the seating engineers about. They were interested in cutting the number of motors down to reduce packaging size even if the required extra mechanical bits to keep the same motions negated the cost.
jzinckgra
Maine
2020 Ranger Lariat
Not to nitpick too much, but the lack of power recliner apparently negated Ford putting in memory seats. On occasion my wife drives my truck and I like getting my seat positions back to the exact position they were in. Without memory, I have to make adjustments for a bit.
Kataphrakt
Tim
Seat memory AFAIK is similar in issue to outside-mirror memory. Most systems on US vehicles use a door module (AKA a computer in the door) to control those functions, as well as typically being relied on to manage auto-fold (i'm not sure how the architecture of this all works, that's for the EEs & CEs to play with). But for memory systems, this is a key issue as most memory systems i know of make use of what is basically a potentiometer to report the position. Decoding this position requires an Analogue>digital conversion to read the voltage that was sent and compare that to the voltage that was received. One could just run this wiring all the way back to the ECU, but voltage drops with wire length, your risks of interference increase greatly, and vehicles are typically very noisy with EMI. To get consistent results the position has to be read from nearby -- plus the buttons for this are typically on the door so you dont have to route as much length of wire. For the OEM, this makes things simple as there's little communication that has to happen. With memory there might be no communication between the door module and the ECU, while something like auto-fold might be programed in so that the door module folds the mirrors when it receives the signal to also lock the doors.
From what i know working with Mirrors sub-groups in Asia and Europe, door modules are not particularly common over there and they're having a hard time selling OEMs on switching to them. Odds are Ford either didnt bother to try to put a door module into the US ranger, or they didnt have space in the door for it.
VAMike
That's the big one for me. I can get the seat adjusted (eventually), but I really miss "instantly recover from someone else driving my truck" as a feature.
Reactions: EJH
It’s not a matter of technology as it’s been there for decades already. It all boils down to cost and returns. Seat skeleton costs them $280. Still has to be covered and wired. Typically 3 buttons of old were 1, 2, stop. Then additionally the power seat buttons. When it’s all said and done with today’s costs it’s a break even game.
I had a mountaineer that had 8 way, inflatable lumbar with memories and heated leather.
They could do it if they made $600 on it ?
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
1. Yes, It really sucks to save fuel.
2. Take off the clown shoes.
Exactly. The solution is simple. Wear smaller shoes.
VAMike
Hopefully competition in midsize trucks will make all the manufacturers try harder--IMO they've all been delivering mediocre products because there's not been a better alternative.
