Wiring Diagram??
vincenzo
vincenzo
italia
ranger
Salve sapere dove trovare diagram completo x ranger T7 anche a pagamento? Grazie
ymboc
Canada
'21 Ranger
@ScubaSteve
Are those diagrams excerpts from AllData or Mitchell? Any pointers where the best place might be to order a one-time complete set of wiring diagrams (as opposed to a subscription)?
Thanks!
swinstallion
Matt
Brisbane
2021 px3 xlt
Builder
@Caluke
Hi,
Would you have the diagram for the plug for the reverse sensors? Similar 6 pin with only 5 used.
Thanks
Here you go, Let me know if you need any more info. I'm not sure if there are any other associated connectors.
Wings06j
USA
2020 Ford Ranger XLT
Any chance of getting the pin out for the driver seat harness that connects to the seat heater? Ideally also looking to trace where those wires connect to. I'm considering buying the heading mats and attempting the install but need to see if I even have a prayer of running the wires.
Caluke
Lucas
Automotive tech
Pretty sure this is what you are looking for.
20XLRangerFraptor
Clifford
Waddell, AZ
2020 Ranger XL
Jet Mechanic
@Caluke
you wouldn’t happen to have the pin out for the connector for the headlight switch? Looking for the link it for the factory fog light switch. I got my truck used and I know it didn’t have factory dogs installed but I have a switch panel that has the factory fog light button on it. Try to see if I can pin the connector so I can use the factory switch to turn some aftermarket fogs on.
@Caluke
From one wrench to another - Here you go
jblc
JB
USA
2021 XLT FX2 supercab
Would you happen to have the diagrams for the center button console, for sync3? Just the console that has buttons/lights (HVAC and radio buttons). This is for the recirc project. Thanks :)
rangerrichie
Richie
uk
ford ranger
Firefighter
has anyone got any info on where the connector is for the plug and play canopy/hardtops is?
I do not have a toper on mine, but those who have it, are using 2 separate sources.
1 to extend the 3rd brake light and another for topper lighting (ceiling)
May not be the same though as for UK version as external lighting wiring is completely different.
Non-US versions of the wiring diagrams are very difficult to locate, but the install instructions for the topper should direct you to it.
You may try searching for Topper on this forum for further direction. I think for BLIS there is a 16-pin connector that is tapped into, located on the driver's side frame rail just under the tailgate.
and for the Topper light (ceiling) I think they tap into a connector in the left rear wheel well area.
I can dig some to find it but would rather have someone who has actually added the topper to confirm.
One thing to note, the Ranger HATES having anything added to lighting without issues, it is adding resistance to the circuit.
Thats why it is important for you to read the various threads on this before you do it, to hopefully eliminate any issues with it. (lights not working, and the most common hyper-flash)
JT17
Hi all!
I just put a deposit down on a SuperPacific canopy camper unit. I’m looking into the best way to wire up the third brake light.
also, I found an actuator kit (gatekeeper: https://mountainyotas.com/shop/tacoma/canopy-camper-keyless-entry/ ) that is supposed to tie into the factory door/tailgate locks so you can lock/unlock the camper handles with your truck fob. But it’s made for Tacomas and originally meant to also tie their tailgate into the key fob locks (which the Ranger already has). Curious if anyone would have any recommendations on best spot to pick up power for the door locks.
thanks!!
Hi all!
thanks!!
If you have the Power Door Lock Actuator at the Tailgate, the easiest would be to tap off of that actuator.
Gray/Brown = Lock (Pwr)
Brown/Green = Unlock (Pwr)
The Ground is provided by the BCM Wiring through the Central Lock / Unlock Relays all of the door locks share that ground point.
JT17
thank you!
JT17
So your note about the ground, am I understanding that to mean I don’t need to wire in a separate ground for these actuators (AKA the circuit has its own ground through the BCM wiring)?
thanks for the patience…very rudimentary wiring/electrical skills in my toolbox.
Thanks!
