RangerJeff
- Thread starter
- #1
Has anyone gotten ahold of a wiring diagram yet? Specifically looking for the wires and pins for the tailgate harness, and the rear view camera.
Thank you!Here you go, Let me know if you need any more info. I'm not sure if there are any other associated connectors.
I will take a look in a few minutes and post up what they have.I am looking for the heated seat connectors so that I can disconnect or terminate the circuit for the bottom element and leave the back element circuit intact and working. Please help if you can. Thank you.
Looks like the seat bottom and backrest heaters are daisy chained together, going to require cutting and adding a wire to disable the seat bottom heater.I am looking for the heated seat connectors so that I can disconnect or terminate the circuit for the bottom element and leave the back element circuit intact and working. Please help if you can. Thank you.
Yes, exactly, looking to see if there is a satellite radio antenna installed even though my factory radio doesnt have an xm/sirius option. I installed a commander touch aftermarket radio that came with the standard mag mount xm antenna, but if I can tie into the factory antenna, I'd much rather so that. Thanks again!@ScubaSteve sounds like you would like to know if the OEM 4” xlt radio/sync system has a satellite antenna for Sirius XM radio? Or are you looking for GPS also? What head unit did you install? It may require an adapter. Thanks.
Thank you!@ScubaSteve The wiring diagrams do not give specific information on every trim level this is what it shows for Sync equipped vehicles.
