Wireless Charging Install
mokupilot
The Aloha State ?
22 DeeZee Lariat Tremor, 09 Escape Limited
Heavy aluminum tube logistics and transportation ✈
the charger recommended earlier in the thread wasn't available when I bought mine, so I got a different one that looked very similar.
I'm also using an Otterbox Defender Pro case that's rated to be used with wireless charging, if that makes a difference.
anyone have a current known reliable wireless charging pad link available so I don't have to dig through 22 pages of posts for it?
Iv’e used this one with Dirk’s tray since July. I didnt like the little car logo and the ring glows green in the dark. I also wired in a separate power supply for faster charging and use an iphone.
https://www.amazon.com/gp/product/B09MYNNKV9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
BOCTOK
2022 Ford Ranger XLT
Analyst
Dirk's tray is 1000% worth it. Perfect fit and looks great! The charging pad was the only weak point. I have an Otterbox case and it works just fine with all of my wireless chargers in the house, but for some reason, I was having trouble getting the phone into the sweet spot on the Car Wireless pad. I had already purchased another pad from Amazon (Sanmido) that appears to have a slightly larger coil area within the pad. It also fits snuggly into Dirk's tray. No problem with the phone charging on it. I will find another use for the Car Wireless one.
DirkM
Dirk
Chicagoland
2019 Ford Ranger Lariat FX4, 2021 Audi Q5 PHEV
The car wireless charging pad hasn't changed since the beginning but as all QI based chargers, there are various limitations. If the phone is not perfectly centered, it gets hot. And most phones only charge with 7.5W on QI which is much less than wired charging usually allows. The car wireless charging pad supports up to 15W if the phone is compatible, perfectly centered and if it is connected to a QC3.0 power source.
The Sync 3 USB-A ports only supports about 2A at 5V with is 10W max. Enough for wired charging of a single phone (and CP/AA through that wired connection) but not enough to power a wireless CP/AA adapter plus a QI charging pad.
The only way to get a reliably higher wireless charging rate is Apple's MagSafe on iPhone 12 and newer. These charge with 15W if connected to a 30W PD USB-C power source and the iPhone is always perfectly centered.
mtbikernate
NC
2019 Ranger XLT 4x4
My phone supports up to 15w wireless charging, and I installed the QC 3.0 port for the charging mat. that part appears to work just fine.
I guess I should investigate whether it's perfectly centered or not. I'm not using your base because I like a different orientation of my phone (we've had a conversation about that in the past), but if that orientation is preventing my phone from aligning with the charging mat properly, then I'm going to have to do something differently.
mtbikernate
NC
2019 Ranger XLT 4x4
so I bought this charger, hoping that the larger charging pad area would help with the overheating issue, at least. time will tell on that.
it doesn't help with the BT interference/restarting problem I'm having, though. I think I'm going to try relocating my AAWireless puck. It's currently hiding beneath the charger in the tray, but I'm going to try putting some adhesive velcro on it and sticking it to the underside of the center stack to place it above the phone/charger. might help with the interference issue?
mokupilot
The Aloha State ?
Possible. Heat kills electronics. I have an iPhone and I think they charge more slowly than android. My pad might produce less heat with my phone. I have the Bluetooth module taped to the bottom of the tray and it’s only slightly warm. I’d relocate yours like you plan.
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Ford ASSET Instructor - Program Director
I think there was a firmware update that mentioned the restarting issue. Have you opened the App and updated the interface through the app?
mtbikernate
NC
2019 Ranger XLT 4x4
AA Wireless firmware?
I looked awhile back and there wasn't anything at that time. I'll check again.
** Just checked. Nope, mine's up to date.
jlinarez
Jorge
USA
Ford Ranger Lariat 2019
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
How was the fit with this mat on Drik“s tray? Do you have a picture?
Its appears to be a little smaller so should work. And 15W vs 10W so might charge faster.
Might give it a try as I have noticed when using my phone with AA wireless the 10W pad does not keep up.
And I had already wired in a higher power USB port
mtbikernate
NC
2019 Ranger XLT 4x4
I changed over to the Sanmido a few months ago and last week did my first long road trip with it. It's marginally better than the car wireless one. when the phone is running AA, it adds a little bit of charge over time, but it's not what I'd call fast. biggest thing I noticed with it, though, is that my phone doesn't get so hot on it. so that's a big plus.
I also wired in the higher powered usb port. I may wind up just putting a cord into that port instead of the wireless charging pad so I can actually get a decent charge fairly quickly.
DirkM
Dirk
Chicagoland
Most phones are limited to 7.5W wireless charging (all iPhone at least unless it's a MagSafe charger).
mtbikernate
NC
2019 Ranger XLT 4x4
I have a Samsung Galaxy S22. Reportedly will do wireless charging up to 15W.
Whatever it gets from the charging pad, it's barely more than it's using when running AA (and with the car wireless pad, it seems about equal - except the phone gets too hot and shuts down).
