Truck going back to dealer
bearrug
Idaho
2021 Ranger STX 4X4, 2023 ford Bronco Sport
Last week took truck to dealer ,the transmission was doing a clunk between 9th and 10th gear, up shift and downshift ,mechanic took it for a spin and confirmed it but is 2 weeks out to work on it plus they have no loaners for me to drive also having problems getting parts, hopefully i can drop it off this friday ,only have 16000 miles on it, sure glad i have a warranty on it, probably could have avoided this problem if I would have installed a damper.
Could you keep driving it while they are procuring parts and just lock it out of 10th?
bearrug
bearrug
Idaho
yeah im still driving it to work I just let it clunk hopefully it will last for a few more days.
You can lockout the gears with the +/- buttons on the shifter. I would just lock out 9th and 10th and drive it easy.
Since you brought it up (see guys I didn't start this ? ) I don't think the damper would've helped as it adds way to much hp/tq. ?
bearrug
bearrug
Idaho
LOL yes i got you off the hook with the damper , yeah i will probably just use sport mode and take it easy glad i still have 8 more gears.
Just so you know, what he's talking about is using the +/- in D to simply lock out 9th and 10th.
I'd do this over full on S just to take it easy on the transmission.
bearrug
bearrug
Idaho
oh ok yeah your right
GregsFX2Ranger
Greg
2021 XLT 302A 4x2 Rapid Red Black Appear Package
Management
I love that +/- button. I rarely put mine in 9/10th unless I'm over 60. Seems like it "lugs" in 10th under 55.
Even at 60mph in 8th, its only @ 2000RPM, so no worries. Over 60, in 9/10th, it drops down to about 1600rpm
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
Hope it's nothing serious David. Please keep us updated. One never knows, but the fix may be helpful if needed. Good luck.
bearrug
bearrug
Idaho
Thanks, yeah i will give an update when they get done
bearrug
bearrug
Idaho
When i did talk to the service guy he did say they have to take the pan off and apply air to the valves to see if there moving correctly or something like that if that makes any sense.
mlarma
2020 Ranger XLT 4x2
Computers/Networks
this is true, if a damper was installed, the problem would have surfaced before the first oil change at 3000 miles.
Confirmed. Had to get valve body/solenoids replaced at 2100. Got oil change and transmission fluid change too then. Also I did thankfully have a loaner Ranger.
