- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,499
- Reaction score
- 8,592
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
The importance of knowing if the Door Opening would trigger the Wake Up, is to know if the PCM Relay was getting power, but after looking at it and you were able to remote start the truck, I concluded that the PCM Power Relay was getting power., as the PCM Power Relay (Wake) up is triggered on by both actions. (Remote Start) & (Door Opening)
The Relay is in the Engine Bay (Fuse Box) - #15 (Run/Start-Relay)
As Phil stated and how Dealerships work, they are driven to Code Based - Troubleshooting
There are times when you have to take all codes and throw them away as they will lead you down the wrong rabbit hole, Hence, they replaced the ABS module (Code Based) due to the fact that the ABS and PSCM are the (2) most logical modules in that Code List to be faulty.
I have seen many times dealers say, No Codes, No Problem Found - Drive It Awhile and see what happens.
I went through some of those Codes, but the problem is, unless the truck is in active failure at the time of the testing, they would never see the voltage missing on the modules past the Run/Start relay.
Now, since you have had the truck to the Dealer multiple times, talk to the actual tech that will be working on it.
They hate customer troubleshooting. And as you said, ignore you and throw it in the trash.
But I am very certain. with all the symptoms you have, the Run/Start Relay is the issue. Take all the codes and only focus on the Communication side of it, there are a lot of them, this points to a voltage loss somewhere and that somewhere points directly at the Run/Start) relay.
Tell him to look at the - Wiring Diagram for Power Distribution (Pg 2 of 7) or print off the PDF I included and hopefully he will see what I am looking at.
Be sure to inform him about being able to remote start the truck and then it dies (in gear)
and inform him of all the fault codes you get while driving it
Those (2) scenarios alone again point directly at the (Run/Start) relay, this is how I came to my conclusion. (Not via Codes) but by what the truck was actually doing (Owner's Input) and by using Owner's input followed the logic and then the code-based faults showed why they are being generated.
The Tech needs to be attentive and listen to you and have them look at the Run/Start relay first, check for voltage there with key on, and you should have a ground signal to the relay
You can check to relay itself (out of truck) by test leads, Positive on both upper legs, and apply ground on the BCM (Lower) leg, (you should hear a click) in the relay, and while that ground is applied, check for voltage on the output leg going to the modules.
If your beginning point starts at Code Based on this particular issue you are chasing your tail as it will force, you to look at many variables and take forever to locate the actual fault, (if that relay is not in current failure) they will not even think about it, as they will have positive test results for voltage.
